Loading IC-306 Fiery software without machine attached.
  • wjurls
    • Feb 2017
    • 505
    Like the title, I have a C6000 with an IC-306 Pro 80c Fiery that is hung up on starting up. Brought some system discs with me and it doesn't want to load. Maybe bad HDD, Bad DVD-Rom? Either way I am bringing this into the shop to try and resurrect it where I have more resources.
    The question is, Can the system software be loaded onto the Pro-80 Fiery without it being attached to a machine?
    Will it get so far and then hang? Or will it not get started at all?
    Thanks,
    Lee
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Loading IC-306 Fiery software without machine attached.
    yes it can be done with no machine attached.
    you can load system software via USB or disk.
    just be careful about versions. the later versions of SS are win 7 and need a bios and ram upgrade to install.
    does it have a FACI kit? you can still hook a monitor to it and see up until windows begins to load then the screen goes blank. (usually a good sign) but see if the HDD is even seen during POST or maybe detects a SMART error so you know the HDD is toast.
    • wjurls
      • Feb 2017
      • 505
      Thanks Synthohol, I found the system printout that indicates this has been updated to ver 3.01. Ver.s 3.0 adds FACI so I could get a monitor on it. I could breifly see the POST and it showed a Hitachi drive. Would then go to boot from CD and nothing. Turns out to be a toast CD-Rom. I rigged up a different drive20201228_141934_resized.jpg and was able to boot from the 3.01 system disc. This got me to a point where I could try to do a system recovery. It's still doing it's thing so we'll see I guess. Before this I would just get a blank screen after the POST20201228_154725_resized.jpgBeen at this screen for quite some time now.
      • Synthohol
        • 5922
        Awesome McGuyver man!
        • emujo2
          • Mar 2017
          • 1579
          Not gonna help with your issue, but..I have had many PCs over the years..everthing from 40MB (yes MB) to 2GB drives. Some of these PCs ran for 8 years or more..Never have I had to replace a HDD (upgrade, yes) in any of these..I cannot even begin to count the amount of HDDs I've had to exchange in copiers/printer. WTF why do so many of these go bad..E
          • Synthohol
            • 5922
            The trend of bad hdds seems to be related in poor voltage fluctuations IMHO.
            8/10 times the surge protector we have on all the machines show surges, undervoltages and outages recorded on them.
            I'm not suggesting it's always the main cause but it really does not help at all.
            • wjurls
              • Feb 2017
              • 505
              Still battling this one. Hoping Konica left the customer with the software. I won't know until my contact returns on Monday. This particular Fiery was upgraded to ver 3.1 in the past and therefore won't accept the Linux based version 1.1 system code that Konica has made available. The recovery attempt above failed and my only hope is a new HDD followed by system 2.0 then up to 3.0.
              According to KM 3.0 can only be installed on a 2.0 system. Is this correct? Or if I get the 3.0 system discs, can I load it to a bare drive?
              Lee
