Minolta di2010 on windows 10
  • DannyL
    • Sep 2025
  • tsbservice
    Field tech
    • 8077
    Re: Minolta di2010 on windows 10
    Check out this thread:
    Minolta Di2010 Windows 7 driver?
    Or you can try to download existing driver for older Wndows versions and use Windows Troubleshoot compatibility option.
    • REGSIS
      • May 2016
      • 440
      Di2010 isn't 64-bit compatible, only 32-bit drivers come to play.
      Never tried this, anyway.
      • Synthohol
        Certified Konica Expert
        • 5913
        i had luck with hp laserjet III drivers on older machines, no finishing options or pretty much anything but it has worked in the past.
          +1 HP LJ4 also works
          • femaster
            • May 2011
            • 1527
            Looking in the tech portal, there are 64-bit PS (Post Script) drivers available for this model. They are XP/Vista 64-bit, released in 2007, but MIGHT (and that's a HUGE might) work if they are installed through compatibility mode in Win 10. All you can do is try. If it doesn't work, then it doesn't. You could also try and see if Win 10 will allow you to install the 32-bit PCL driver (again, Vista is the newest). It won't be like you are out anything for giving it a try.
            Good Luck!
              • 37644
              When Microsoft dropped support for all Windows versions prior to Windows 7 most printer/MFP manufacturers dropped the listing on drivers for all older versions of Windows. I don't know about Minolta but prior to that time all Ricoh drivers for XP through Win 10 were the exactly the same, same version and download size. You just had to order for the correct processor, 32 bit or 64 bit. To be on the safe side I would recommend using their Win 7 drivers.
                • 15063
                Also, if I remember correctly, there needs to be a PS kit installed in order for the postscript driver to function. Otherwise you need to locate a PCL driver.
                • skelband
                  • Jan 2019
                  • 62
                  Also worth bearing in mind, IIRC, Microsoft made a large departure for their driver model in Windows around about the time of Vista.
                  A lot of stuff stopped working around that time if the manufacturers couldn't be bothered to port their driver code and reissue new drivers.
