654e firmware needed, can't find on Konica Dealer Portal
  • Dougtech
    • Apr 2011
    • 113
    Hi all,
    I have a 654e with a c-d012. I put in a new HDD but understand I need to do firmware to get rid of the code.
    I can't find it on the dealer portal, product support, or in the firmware server.
    Anyone know where it is or can provide it to me?
    Doug
  • Bix
    • Apr 2018
    • 1421
    Re: 654e firmware needed, can't find on Konica Dealer Portal
    This code requires you to logically format the HDD.
    SM - State confirmation - Memory / Storage Adjustment - Format - Logical Format.
    • Dougtech
      • Apr 2011
      • 113
      Hi,
      Thank you for your help. I have done both physical and logical but cannot seem to clear code unless HDD is uninstalled in SYSTEM 2. I will also need to get the animation - movie file for this model if anyone has it. I only have the C654e files.
      Doug
      • femaster
        • May 2011
        • 1526
        Originally posted by Dougtech
        Hi all,
        Doug
        Not sure if you were looking for a specific firmware or not based on your post. Since it sounds like you have access to the Dealer portal (assuming you are in the US based on your AZ [Arizona?] location), I've included links below to the latest base firmware available, and the movie firmware that you requested in a later post. Make sure you are logged into the Dealer Portal before clicking the links below, and it should download what you are after.
        Base Firmware: 654e 754e_A55V0Y0-F000-G20-M0.exe
        Movie Firmware: A55V0Y0-C000-G00-00 1st_Movie.exe
        Good luck with your repair.
        • Bix
          • Apr 2018
          • 1421
          Hi,
          Doug
          I don't think the problem is firmware related. Maybe a simple trouble reset is needed.
          • Dougtech
            • Apr 2011
            • 113
            Thank you, I was able to download the files. I am going to format the drive again and install the FW to see if it takes care of the code. Will let you know.
            • Dougtech
              • Apr 2011
              • 113
              SWEET! I loaded the firmware and now the code is gone. Thank you so much for the link.
              • femaster
                • May 2011
                • 1526
                No problem, glad it helped.
                I just tried the links, and it appears that the links are valid, even if you aren't logged into the portal. I guess those 2 links will be a free-for-all for anybody that wants them since I can not edit the post to remove them. Live and learn I guess...
                • djdn
                  • Jun 2021
                  • 9
                  Are the firmware links listed earlier in this post legal for use? We are not a dealer. I am getting D012 error and the unit wont print copies after the Overwrite All Data was performed. Would like to know a better way of getting around this since I probably wont be able to download a legal copy and I'm guessing you have to be a dealer in order to do so.
                  • Synthohol
                    Certified Konica Expert
                    • 5905
                    the links in post #6 seem valid.
                    i dont see a problem
                    • djdn
                      • Jun 2021
                      • 9
                      Thank you. didn't know if a license was needed or something.
