C308 Erro C-D011
  • avecosat
    • Jun 2012
    • 305
    #16
    Re: C308 Erro C-D011
    If you have C-D011 just have to change or format the hard drive but if you have C-FA14 , C-D050 you need to do recovery
    • M94
      • Jul 2020
      • 158
      #17
      Not that this hasn't already been said, but just so it's perfectly clear.
      HDDs can still absolutely have functionality for even months after they start dying. It showing up on a pc and even being able to browse the files isn't a guaruntee that the drive is fully functional. Unless you are using a sector-by-sector scan and verify utility there's no way to know for sure if it's failed (unless of course it stops completely)
      Drives are cheaper than good software to diagnose them and if the customer isn't using any of the storage functions size is probably irrelevant.
      Replace.The.Drive.
      Edit> Or the firmware others have been posting, but I would assume (bad habit I know) that you would have tried that before removing the drive.
      • barber782
        • Aug 2011
        • 286
        #18
        • kasser
          • Jan 2021
          • 7
          #19
          Thanks for all for the answer first time.
          I misunderstood something regarding the status I am a technician but not a printer technician, I work in the network and administration area. Sorry for that. The contractor my with this error the hard drive is defective and the action costs at least 600 €
          I find it too expensive.
          Because of that I need help.
          I think it's weird that you have fun with other people just because they weren't very well informed like you.
          I thank you again and wish everyone a good weekend.
          I am still grateful for any help.
          In any case, I am very grateful for all of the productive answers.
          • copier tech
            • 8237
            #20
            Before you playout on a new HDD (you can use pretty much any 320GB HDD they cost peanuts on eBay by the way) get your engineer or yourself to update the SATA firmware as I said & a few others in this post. The HDD maybe perfectly OK.
            • kasser
              • Jan 2021
              • 7
              #21
              Thanks I have a Toshiba MQ1ABF050 500GB here, it's ok from the size.
              I don't have any smaller ones.
              just plug it in and then? otherwise I'll buy one
              • copier tech
                • 8237
                #22
                Yes, just plug it in then if it doesn’t prompt you to format it perform a format in CE mode.
                • kasser
                  • Jan 2021
                  • 7
                  #23
                  Hi there, thank you thank you thank the error is gone.
                  I got the error now: data for the animated instructions not installed. Contact your service technician. I can now also copy and scan,
                  but the error message is there I think I must import various data, but I can't get hold of it.
                  Can someone send me this data, maybe even the latest Firmware. Thanks in advance to everyone.
                  • copier tech
                    • 8237
                    #24
                    Glad you fixed it.
                    You can ignore that message it won't stop the machine from working.
                    However should you want to remove this warning you'll need to install the animation movie file firmware.
                    Drop me an email if you need it.
                    Firmware Update - Printer & Copier Firmware
