C308 Erro C-D011
  • kasser
    • Jan 2021
    • 7
    C308 Erro C-D011
    Hi there, I have a Bizhub C308 error message C-D011. I removed the hard drive, I can read it seems to be ok Can someone help thanks
  • barber782
    • Aug 2011
    • 286
    Re: C308 Erro C-D011
    Update the Sata firmware to version 4.
    Download my attached file with instructions.
    Sent from my VTR-L09 using Tapatalk
    • Gift
      • Mar 2011
      • 2459
      Have you tried just installing a new HDD? A faulty one might appear OK on a computer.
      I think there was also an issue with the S-SATA controller with that series, therefore KM issued some "S-ATA FW update", you'll probably find some topics about this here.
      • kasser
        • Jan 2021
        • 7
        Thank you very much for the quick reply. Sorry, I can't download the attachment. Error message
        Invalid Attachment specified. If you followed a valid link, please notify the administrator
          why don't you READ THE MANUAL?
          show us you made an attempt to read and diagnose the problem yourself.
          • kasser
            • Jan 2021
            • 7
            Sorry if I don't understand. Which instructions do you mean?
              get the service manual
              read the service manual
              NO NEWBIE should attempt a repair WITHOUT The fucking manual.
              even senior techs have the manual.
              replacing the HDD requires many steps and different instructions on formatting ... loading firmware
              how much time have you spent on this problem already?
              this goes back to a bible verse:
              give a man a fish ..he eats for a day.
              TEACH a man to fish.. he will never go hungry..
              GET THE DAMN MANUAL.. READ it and SHOW you have at least tried to fix it yourself. We aren't here to do your work for you but rather to help when you can't go any further.
              that error is clearly defined and how to fix it in the manual.
              • kasser
                • Jan 2021
                • 7
                Thanks for your nice reply. I don't want to change the hard drive. I don't think it's damaged. I have removed it and connected it to my PC and see all partitions on it. Again the question of which instruction manual and where can I get it. thanks
                  just because you can see partitions on the drive DOESN'T MEAN it'll work on the copier... the info for the system could be corrupt not allowing the copier to boot properly.
                  THE SERVICE MANUAL is what I am talking about.
                  you haven't even looked over the different forums here at CTN have you... go to forum main menu... look for MANUAL REQUESTS... post a request there.
                  even now I am having to do your damn work for you.. no more I'm done with fucking lazy techs.
                  • Synthohol
                    Certified Konica Expert
                    • 5910
                    wish i can fix machines by thinking parts are good.
                    • Gift
                      • Mar 2011
                      • 2459
                      calm down man... I know what's triggering you but it makes no sense to yell around, that's not healthy for any of us, you included^^
                      But yes, we both stated that a simple functional check via pc does not really tell one about the data integrity. So I would a least wipe/format the HDD and see what's happen if you put it back to the MFP - or just install a new one wich most techs should have in their default car-stock.
                      If you're not a dealer/tech: there's a nice company in Bielefeld called "von Busch" iirc....
                        ok genius tell me what is triggering me?
                        a lazy tech the doesn't have a manual and simply relies on the knowledge of others without making an attempt to TRY and resolve it himself?
                        Please enlighten me.
                        • Gift
                          • Mar 2011
                          • 2459
                          Well, what's triggering me sometimes is that some customers probably would outsmart some so called "techs" asking for help here. Weird ways of analysing things, not use the search function to gather already existing discussions or ignoring good tips and hints that has been posted in their own threads - that's usually the stuff I find annoying.
                          I'm not shure if the thread starter is a tech or owns the manual but at least he seemed able to found an information that this error code might be related to the HDD and made an attempt to check the HDD.... so this one won't qualify for a Pulitzer but isn't really the best example for how low you can go here
                          • copier tech
                            • 8235
                            This is a known issue, if your HDD is good update the SATA firmware.
                            • Bix
                              • Apr 2018
                              • 1421
                              Hi, I have had a similar problem. Never trust HDDs.
                              I had also tried replacing it with a HDD used by a high printer. I solved it just by changing to a new one.
