Bad network connection
+ More Options
Posts
    • 30409
    #16
    Re: Bad network connection
    Phil,
    I just went to my virtual lab and I see what you're saying. From Windows Server 2019, I can exclude any device from obtaining a DHCP address by entering the MAC Address of said device. Never thought about that. Good call.
    How did you think they lock networks down
    Basic networking
      • 16455
      #17
      I never claims to be an expert on networking and servers.
        • 16455
        #18
        Basic networking
        bsm2,
        I was so busy playing around with the advanced features in Server 2019, that it never occurred to me that a network needs to be locked down. I got it now, tho. Thanks.
          • 30409
          #19
          bsm2,
          No worries most of them are not locked down. Usally enterprise size networks , Government, Banks etc....are locked down.
            Phil,
            i learned that by being an NA at my last job.
            • emujo2
              • Mar 2017
              • 1579
              #21
              I'm gonna call BS on this..most laptops are not running DHCP assigning services, that is more a server based application..E
                key word the is MOST I have mine setup to do just that.
                so pull your BS back brother, IT can be done.
                • allan
                  RTFM!!
                  • 5462
                  #23
                  Silly question. Why would you want to setup your laptop as a DHCP server?
                  Always had weird issues if there was more than one DHCP server on a network.
                  Whatever
                    separate boot into server software just for trouble shooting ... comes in handy when at a customers site. Blows their IT dept claiming it was the copier/printer
                    it doesn't connect to their net...
                    • allan
                      RTFM!!
                      • 5462
                      #25
                      Seems like in this case the OP had no need to connect the laptop directly to the printer.
                      Whatever
                        no he needs to investigate THEIR network print/scan works fine
                        • tsbservice
                          Field tech
                          • 8032
                          #27
                          As always update the FW and set switch 25 accordingly. And as others mentioned play with network speed and TLS, SSL settings.
                          Try this:
                          Select Administrator
                          Select Settings
                          Select Security Settings
                          Select Security Details
                          Select Initialize.
                          • D_L_P
                            Self Employed
                            • Oct 2009
                            • 1196
                            #28
                            Originally posted by rrrohan
                            Laptop connected on same port with same cable works fine obtaining...
                            ...Ping using laptop on same port works with no drops.
                            Those two bits of info eliminate the customers network and cable as a problem.
                            Ping drops about 15% of the time
                            And that points to the copier NIC. I agree with you about time for a MFP board.
                            15% ping drops may not stop a print job but would impact a SSL handshake for email.
                            • D_L_P
                              Self Employed
                              • Oct 2009
                              • 1196
                              #29
                              Exactly the opposite
                              Explain?
                                • 30409
                                #30
                                Originally posted by D_L_P
                                Explain?
                                Can't web in first clue
                                Most likely a duplicate Ipaddress
