Bad network connection
  • copier tech
    • 8188
    #31
    Re: Bad network connection
    Can't web in first clue
    Most likely a duplicate Ipaddress
    But DHCP would not pick a duplicate IP thats one of its main jobs.
    โ€‹
      • 16446
      #32
      The OP is saying that DHCP won't pick an address at all for the copier. I'm pretty sure Phil is right that the copier has been excluded from getting a DHCP address thru the server settings.
        funny that an IT manager didn't know that fact...
        oh yeah it has nothing to do with FTP which he is an expert *cough* at.
          • 30355
          #34
          Konica copier doesn't tell you there's a duplicate Ipaddress like some other manufacturers.
          There IT could or he could unplug the cable and ping it.
            • 30355
            #35
            HILARIOUS copier has a static ipaddress
            power failure another device grabs the same ipaddress of copier.
            PS on Konica and others the last thing to boot up is the NIC
            card.
            That ends today's lesson
            • D_L_P
              Self Employed
              • Oct 2009
              • 1196
              #36
              On Kinica's HTTP protocol can be disabled in one of the admin menus. It will still print and scan but the web interface won't load. It appeared like a firmware issue but the HTTP protocol was turned off.
              Also, a duplicate IP would't stop any device from obtaining an IP:
              Originally posted by rrrohan
              Also if i put on DHCP it fails to obtain a IP
                • 30355
                #37
                Yes you can turn it off web page but very very Rare that happens and it's the main way to program the machine. But a duplicate Ipaddress will definitely block you from viewing the web interface.
                Hopefully we will all get more information from the Tech or mabye not. Some of his comments are conflicted.
                • tsbservice
                  Field tech
                  • 8029
                  #38
                  Not agree on what you're implying...He's definitely trusted tech knowing his stuff.
                  • emujo2
                    • Mar 2017
                    • 1579
                    #39
                    KMs do indeed inform the user through the control panel that another device is using the IP address. All I'm saying is I would be hard pressed to replace a MFP board based on what the poster is saying the machine can and can't do. It can print and scan..packets being dropped can come from anywhere. Corrupt SSL certs and bad softswitch settings can be corrected through initialization..and/or HDD formats..E
                    • srvctec
                      Former KM Senior Tech
                      • Oct 2009
                      • 827
                      #40
                      Talking about the original tech
                      thank you
                      TRY and keep up
                      Pretty sure tsbservice was talking about the original tech rrrohan (correct me if I'm wrong, tsb!), you know, the OP of this thread.
                      bsm2, do you have to work hard at being a douchebag or does it just come naturally?
                      Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                      • emujo2
                        • Mar 2017
                        • 1579
                        #41
                        here's an interesting tip about DHCP and the C308
                        Switch thinks it's a PoE device..Disable PoE (Power over Ethernet) for the switch port...And after re reading the posts..the user drops packets except when connected directly to the device, and his laptop pulls an address on the port..not that the laptop is assigning an address to the copier..(unless I'm just losing something in the non related comments. E
                          very very naturally .... frankly I think he was born with the douche bag gene running at full gallop
                          • tsbservice
                            Field tech
                            • 8029
                            #43
                            You're not wrong of course. Just some guys like to play games deflecting and twisting.
                            • davel
                              • Oct 2011
                              • 1107
                              #44
                              thank you
                              TRY and keep up
                              Great please explain how the machine pulled a DHCP address from his laptop.
                              • emujo2
                                • Mar 2017
                                • 1579
                                #45
                                Ok you 2..I left the BS trump/biden wars thread months ago because of that crap..Can you guys put it aside for this thread???
                                I just tried to program my C360i with a known duplicate IP..Message displayed on the control panel like I said..Copytech wont let me upload the pic though.
