Bad network connection
    • 29909
    #46
    Re: Bad network connection
    I am man enough to admit I made an error reading the call
    please accept my apology.
    Thank You
    • rrrohan
      • Sep 2011
      • 1977
      #47
      Its not a IP conflict. No replies if copiers switched off. Copier would of complained about that if it was anyway.
      Firmware is latest but only function 3.3 so Ill up it to 4.2
      Network speed reduced to 10/100. didnt help.
      IP filtering is not enabled
      I haven't tried connecting laptop directly to copier to see if i can get web access
      also im wondering if the HTTP server/PageScope (or what ever they call it these days) is disabled.
      Ive had a IT guy disable web page by mistake at another customers once before.
      Im going back out now Ill report back.
      • rrrohan
        • Sep 2011
        • 1977
        #48
        Set to 4.2 now I can access web page
        Changed the from address from level1@... to level2@ since I knew level 2 worked and it's working
        Changed back to level1@ and it fails
        Guess it must authenticate via from address? Will question IT on this
        Sent from my Pixel 4 XL using Tapatalk
