C224 Bizhub Bypass Tray and Tray 2 switched
  • hquang
    • Jan 2021
    • 31
    Hi All,
    I am new to this group. I need some help from this group expertises.
    I don't remember what I did when trying to customize the banner printing to the bypass tray and now I can't print to TRay 2 (8.5" x 11").
    I have to use the bypass tray to print to 8.5" x 11"
    Please help me to get back to normal where I can print to tray 2.
    Here is what see on the screen:
    How can I assign the 8.5" x 11" back to tray 2?
    Thanks in advance.
    Hien
  • femaster
    • May 2011
    • 1473
    Re: C224 Bizhub Bypass Tray and Tray 2 switched
    Originally posted by hquang
    Hi All,
    [ATTACH=CONFIG]47946[/ATTACH][ATTACH=CONFIG]47947[/ATTACH]
    Thanks in advance.
    Hien
    Lets start out easy. Paper size in the regular trays is auto detected using sensors inside the copier and is based on the position of the paper guides in the trays. Start by putting the letter paper in the tray with all 3 guides against the paper. If all is working correctly it should read 8.5x11. If that doesn't work, the next step would be to remove the tray and check to see if there might be some paper behind the tray interfering with the size sensors. There is a screwed in metal catch on the left side pillar that prevents the tray's removal. Remove the screw and catch then remove the tray. It may still require a little finagling to get it out. Remove anything that might be back there and reinstall the tray and catch.
    If that doesn't work, let us know and we'll try to further diagnose.
    • hquang
      • Jan 2021
      • 31
      Thanks femaster for a quick help.
      I could not remove the tray because there is another screw and catch on the right as shown on photo. And I see there are two other screws on the right as well.
      I don't see any thing blocking the sensor in the tray. But there is a difference after removing and put back the paper in tray 2: new error message "replenish paper" and the "8.5 x 11" on the bypass tray has gone.
      Please tell me what to do next
      thanks
      Hien
      • hquang
        • Jan 2021
        • 31
        Sometime the tray 2 is seen as for 8 x 13 inch with bypass 8.5 x 11
          • 22973
          So ... do we know if there is paper behind the tray? =^..^=
          • hquang
            • Jan 2021
            • 31
            The tray is clean - nothing else except the 8.5 x 11 paper.
            I did search youtube but found only the how to do this do that. Look like only me or I am the first one having this proplem.
              • 22973
              Not inside the tray. Pull out the tray and look behind the tray.
              • hquang
                • Jan 2021
                • 31
                There are two screws and catch on both side keeping the tray. I was able to remove only on the left side but not on the right side as shown on the below photo
                • hquang
                  • Jan 2021
                  • 31
                  YES, I removed the side and found a paper behind the tray. Everything is back to normal.
                  Thanks femaster and blackcat.
                  • femaster
                    • May 2011
                    • 1473
                    [ATTACH=CONFIG]47972[/ATTACH]
                    Glad you got it figured it out.
                    To be honest, I'm not even sure what I'm looking at in that picture with the 2 screws, it doesn't look familiar to me. Possibly the bypass tray mount?
                    • hquang
                      • Jan 2021
                      • 31
                      it's located below tray 1
                      • srvctec
                        Former KM Senior Tech
                        • Oct 2009
                        • 827
                        [ATTACH=CONFIG]47975[/ATTACH]
                        Not sure what you have circled on top but the bottom circled screw is one of four screws that holds the machine to the cabinet it's setting on.
                        Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                        • hquang
                          • Jan 2021
                          • 31
                          The circle on top is another screw but photo is dark.
                          Problem has been fixed.
                          Thank you,
                          • femaster
                            • May 2011
                            • 1473
                            Thanks. Now that the picture it's pulled back a bit, I can clearly see that now. What threw me off was the long screw that goes to the white glide roller for the tray. I didn't remember ever seeing that before, but then again, unless you are actually looking for it, sometimes things don't stick in memory.
                            • hquang
                              • Jan 2021
                              • 31
                              I couldn't pull the tray out so I removed the left side and took out the paper behind the tray!
                              Thanks again femaster.
