C224 Bizhub Bypass Tray and Tray 2 switched
  • tsbservice
    replied
    Re: C224 Bizhub Bypass Tray and Tray 2 switched
    Originally posted by Gift
    I think the lower screw holds the PC210 front / right located^^
    I don't think so. Like srvctec said it holds desk and mainbody together.
  • Gift
    replied
    Originally posted by femaster
    Glad you got it figured it out.
    To be honest, I'm not even sure what I'm looking at in that picture with the 2 screws, it doesn't look familiar to me. Possibly the bypass tray mount?
  • hquang
    replied
    Thanks. Now that the picture it's pulled back a bit, I can clearly see that now. What threw me off was the long screw that goes to the white glide roller for the tray. I didn't remember ever seeing that before, but then again, unless you are actually looking for it, sometimes things don't stick in memory.
    I couldn't pull the tray out so I removed the left side and took out the paper behind the tray!
    Thanks again femaster.
  • femaster
    replied
    Originally posted by hquang
    it's located below tray 1
    [ATTACH=CONFIG]47975[/ATTACH]
  • hquang
    replied
    Originally posted by srvctec
    Not sure what you have circled on top but the bottom circled screw is one of four screws that holds the machine to the cabinet it's setting on.
    The circle on top is another screw but photo is dark.
    Problem has been fixed.
    Thank you,
  • srvctec
    replied
  • hquang
    replied
  • femaster
    replied
    There are two screws and catch on both side keeping the tray. I was able to remove only on the left side but not on the right side as shown on the below photo
    [ATTACH=CONFIG]47972[/ATTACH]
  • hquang
    replied
    YES, I removed the side and found a paper behind the tray. Everything is back to normal.
    Thanks femaster and blackcat.
  • hquang
    replied
    Not inside the tray. Pull out the tray and look behind the tray.
    replied
  • hquang
    replied
    So ... do we know if there is paper behind the tray? =^..^=
    The tray is clean - nothing else except the 8.5 x 11 paper.
    I did search youtube but found only the how to do this do that. Look like only me or I am the first one having this proplem.
    replied
  • hquang
    replied
    Sometime the tray 2 is seen as for 8 x 13 inch with bypass 8.5 x 11
  • hquang
    replied
    Thanks femaster for a quick help.
    I could not remove the tray because there is another screw and catch on the right as shown on photo. And I see there are two other screws on the right as well.
    I don't see any thing blocking the sensor in the tray. But there is a difference after removing and put back the paper in tray 2: new error message "replenish paper" and the "8.5 x 11" on the bypass tray has gone.
    Please tell me what to do next
    thanks
    Hien
