Konica Minolta Bizhub C284e Internal error occurred
    • 23009
    #16
    Re: Konica Minolta Bizhub C284e Internal error occurred
    Originally posted by rrrohan
    If you temp disable auto internal error reboot on rank C it might display
    Or print a management list. Might show up on last page of printout (I forget the name but it's different to C code log)
    That might be a problem. Especially with C2557 errors you typically get to page 5 before it errors out again. No way will you get to page 13 where the errors are.
    You can also turn off the resetting of internal errors, at least temporarily. =^..^=
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      #17
      Originally posted by Alex1
      I have a Konica Minolta Bizhub C284e with a internal error that occurs, usually in this case i would see a C-2557 or something appears after the reboot. This machine has no errors pop up what so ever and if I go into service mode to see error history its completely blank. Has anyone come across this problem before? Any help would be appreciated.
      I have seen this quite a few times. Usually after initializing all data in service mode on a machine with Bizhub Secure or Bizhub Healthcare stickers. Then it also usually tries to reboot the system immediately in under 1 minute after displaying that error message with no code.
      Can you get into service mode before the machine tries to auto reboot?
      If you can, then verify hdd reads installed, run format both physical and logical. Then reload latest Firmware.
      • Alex1
        • Oct 2012
        • 285
        #18
        Originally posted by blazebusiness
        I have seen this quite a few times. It also usually tries to reboot the system immediately in under 1 minute after displaying that error. Can you get into service mode before the machine tries to auto reboot?
        I tied to get into service mode a number of time when it errors, it won't let you get in. Only after it reboots you can get in.
        • tsbservice
          Field tech
          • 8020
          #19
          This. +1 on turning off Internal Error. Auto Cancel of Rank B and C errors.
          • Alex1
            • Oct 2012
            • 285
            #20
            How would I do the above in service mode?
            • tsbservice
              Field tech
              • 8020
              #21
              It's in Service mode - System 2.
              • rrrohan
                • Sep 2011
                • 1977
                #22
                you could export the report to USB instead
                • Alex1
                  • Oct 2012
                  • 285
                  #23
                  I haven't done that before any help will be appreciated.
                  • Alex1
                    • Oct 2012
                    • 285
                    #24
                    I'll give it a go tomorrow thanks.
                    • rrrohan
                      • Sep 2011
                      • 1977
                      #25
                      pretty sure so long as a usb is plugged in it will have a obvious option to export to usb. been a while since i needed to do it. i norm just print it so forgot how its worded but im sure it will be obvious if u try
                      • Alex1
                        • Oct 2012
                        • 285
                        #26
                        I'll give it a go. Thank you.
                        • tsbservice
                          Field tech
                          • 8020
                          #27
                          List print - select MML -export to USB
                          • Alex1
                            • Oct 2012
                            • 285
                            #28
                            I'm assuming this is under service mode> system 2?
                            • Bix
                              • Apr 2018
                              • 1421
                              #29
                              Service Mode - List outputs
                              • tsbservice
                                Field tech
                                • 8020
                                #30
                                No it's actually under Service 2 button, List Output.
