Re: Konica Minolta Bizhub C284e Internal error occurred
I'll give it a go tomorrow thanks.
you could export the report to USB insteadLeave a comment:
I tied to get into service mode a number of time when it errors, it won't let you get in. Only after it reboots you can get in.Leave a comment:
I have a Konica Minolta Bizhub C284e with a internal error that occurs, usually in this case i would see a C-2557 or something appears after the reboot. This machine has no errors pop up what so ever and if I go into service mode to see error history its completely blank. Has anyone come across this problem before? Any help would be appreciated.
Can you get into service mode before the machine tries to auto reboot?
If you can, then verify hdd reads installed, run format both physical and logical. Then reload latest Firmware.Last edited by blazebusiness; 01-22-2021, 03:07 PM.Leave a comment:
You can also turn off the resetting of internal errors, at least temporarily. =^..^=Leave a comment:
If you temp disable auto internal error reboot on rank C it might display
Or print a management list. Might show up on last page of printout (I forget the name but it's different to C code log)Leave a comment:
Have you tried running the machine without a network connection for a while?Leave a comment:
TNR levels should be around 6.5% one of them may stand out being too low or high.Last edited by copier tech; 01-22-2021, 11:11 AM.Leave a comment:
