Dual Scan ADF sensor cleaning
  • Genotrom
    • Feb 2020
    • 77
    I have seen Dual Scan ADFs that are very resistant to jams. But I have some printers with jams around (66-13).
    I have difficulty getting to the sensors in these ADFs. In normal DFs, it is sufficient to remove many screws but it is easy to get to the sensors. On ADF Dual Scan the covers blocked access to that area.
    What technique do you use to get into those sensors quickly?
  • Bix
    • Apr 2018
    • 1421
    Re: Dual Scan ADF sensor cleaning
    For now, I've never needed to disassemble. But if I remember correctly, you have to disassemble the two side covers to remove the one under the rollers.
    • tsbservice
      Field tech
      • 8020
      Check service manual for 'remove the lower guide assy'.
      • Synthohol
        Certified Konica Expert
        • 5846
        An air can does the job.
        No need to rip apart.
