Bizhub 367 No animation guide!
  • Harcosgemi
    • Jan 2021
    • 6
    [Misc] Bizhub 367 No animation guide!
    Hello. I have repaired a Bizhub 367 but no animation guide. How to eliminate it. I have no use for the manufacturer.
    Thanks in advance...
  • emujo2
    • Mar 2017
    • 1580
    Re: Bizhub 367 No animation guide!
    Remove the HDD..Otherwise ignore it. does not affect operation, but I'm sure someone will offer the file at a cost..E
      load animation files
      it doesn't need the to perform correctly tho
      • Harcosgemi
        • Jan 2021
        • 6
        Can anyone help with an Animation guide?
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5797
          a contributor badge is helpful in your request.
          • Harcosgemi
            • Jan 2021
            • 6
            i need the hdd so i can't remove it. and confusing who writes.
            i hope there will be someone who can help with it.
              WHAT? confusing in what respect ?
              • Harcosgemi
                • Jan 2021
                • 6
                No animation guide.
                Its enoing this message on the device.
                Please send me an animation guide for bizhub 367.
                thank you!
                  No animation guide.
                  thank you!
                  WHAT DOES THIS MEAN " Its enoing this message on the device."
                  you have been told that message won't stop the machine from working.
                  Synth already told you a small contribution to CTN will get you the files you are looking for
                  firmware and ani files are to be used by TRAINED TECHS... do you even have the service manual?
                  • Harcosgemi
                    • Jan 2021
                    • 6
                    yes there is service manual. i managed to find an animation guide.
                    My problem was that before I put the machine into operation, I wanted to put up the amination.
                    It is dissolved. thx
                      • 8132
                      No animation guide.
                      thank you!
                      Happy to help with the movie animation file, drop us an email.
                      Firmware Update - Printer & Copier Firmware
