Konica Minolta C287i prints random text
  • Mtrasa
    • Aug 2025
    Hello everybody!
    In our company we have a problem with random printing. It prints by itself and over night too.
    SKM_C257i21020315020.pdf
    Re: Konica Minolta C287i prints random text
    Originally posted by Mtrasa
    Hello everybody!
    [ATTACH]48127[/ATTACH]
    ASCII code.. you have a corrupt print driver or the WRONG print driver installed
    what driver are you using?
    are you a trained tech?
    • emujo2
      • Mar 2017
      • 1579
      Phil is 100% correct here..you are sending true PS data to a PCL print driver..I have seen jobs like this run until the finisher get's to it's low limit..My guess is you used to send these jobs to HP devices with no problems..You need the download and install KM's PS driver (this is PS emulation, but works pretty well). E
      • emujo2
        • Mar 2017
        • 1579
        BTW the last 2 posts have been regarding machines that don;t seem to be available in the US (no results for C278i or 367)..Am I missing something? E
        • Bix
          • Apr 2018
          • 1421
          Hello everybody!
          Your printer has a public IP. Someone, from anywhere in the world, is printing to your printer.
          Check the firewall or enable ip filtering on the printer.
            then they are using the wrong print driver..
            frankly I don't see this being the case... i still go with the WRONG print driver.
            • B0265
              • Jan 2007
              • 718
              Or someone is trying to attack a router and use the printers ip-address:
              CVE-2018-14847 and Router Compromises (penetrate.io)
              • Bix
                • Apr 2018
                • 1421
                Strangers on the web don't know the printer driver, so they send files with the wrong driver. For a long time, I had a public IP for my office printer because I was waiting for the firewall. Every morning I found papers similar to those.
                Use the Shodan.io website. You will discover a lot of printers with a public ip and default administrator password.
                • emujo2
                  • Mar 2017
                  • 1579
                  Do you know how hard it is to accidently put a printer into the DMZ and allow public access? This is not very likely, but I did see a local university that got hacked via port 25 and print jobs emptied every machine over the weekend..But the print jobs did not look like this..Those wingdings really point to a driver issue. E
                  • Bix
                    • Apr 2018
                    • 1421
                    The problem is that many small businesses don't even know what a DMZ is. In germany we still have companies that prefer fax instead of email..
                    So this doesn't surprise me. The doubt about the public IP arose immediately because the user says that the printer prints even at night, when there is no one in the office.
                    • femaster
                      • May 2011
                      • 1513
                      Could be either one of the 2 suggestions so far, wrong driver, or public IP. I've had experience with both situations, unfortunately. Unless there are employees in the office at night or there is some odd piece of software that prints reports out at night, I'm leaning more to the public IP address.
                      One of our clients was foolish enough to assign a public IP to their C224e, and all hours of the day and night it would spit out pages of random garbage that looked just like that.
                      • B0265
                        • Jan 2007
                        • 718
                        A few years back we had some cases where the printer at customers sites that had port 9100 open in the router was spitting ut pages with the text "your printer is part of a flaming botnet".
                        • Bix
                          • Apr 2018
                          • 1421
                          "Hello, here the printer is possessed!"
                          • Lync
                            • Feb 2016
                            • 47
                            Change the IP address of the printer, someone on the network has probably got an old print driver installed that is pointing to this IP address. (Hopefully it is not a public IP)
                            • CopiertechmyA@@
                              • Feb 2021
                              • 2
                              had the same thing happen with with an end user with toshiba. the end user has something trying to send to the printer driver with no driver. this is a self protecting thing. something is trying to talk to the printer without knowing what it is say. to the printer. change themip and maybe put user codes for safety.
