Reboot Olivetti d-Color MF282plus
    replied
    Re: Reboot Olivetti d-Color MF282plus
    Originally posted by Bix
    I was hoping it would stop rebooting and return an error with used SSD.
    I keep learning from mistakes. Thank you.
    Always worth trying used parts but to be honest in my experience you have a much higher success rate fitting brand new parts & often fitting used boards you create more issues.
  • Bix
    replied
    No, as I said you can't fit a used SSD for this issue.
    replied
    Yes, I also said a few posts ago.
    But the weather was bad in Germany, transport slowed down.So in the meantime I had inserted an SSD used to understand if it stopped restarting. But this technique doesn't work.
  • Bix
    replied
    I have ordered a new SSDB.
    replied
    Hi, good news.
    The SSD used was not working but I received the new SSD (identical for Konica Minolta 4e series).
    Now it works again!
    Thank you all for the support.
    Special thanks also to @occus!
    By the way (it has nothing to do with the problem). For those interested: Konica Minolta toners and drums cannot be inserted on this olivetti 282+. it is necessary to make some modifications to the plastics.
    I told you to fit a NEW SSD!
  • Bix
    replied
    Hi, good news.
    Now it works again!
    replied
    Hello occus, thank you for your reply.
    in germany we are having logistical problems due to bad weather and the parts are arriving late. I have ordered a new SSD which is yet to arrive
    For now I have taken a used SSD to make it stop rebooting. But I have seen that the solution is not effective. The printer keeps restarting anyway.
    Firmware is also unknown. I wanted to try a Konica Minolta firmware because there seems to be no Olivetti firmware on Knova.
    You need to fit a NEW SSD.
  • Bix
    replied
  • occus
    replied
    07-SSD-Firmware-Ver6.05m info.pdf
    TNEU1400013EN_SSD board trouble shooting 1.1[1].pdf
    Bix, do you have a new SSD with green Dot? (with 6.05 already installed?)
    Have a look in the troubleshooting guide.
    If you can't install the firmware i think it is not possible to boot a new ssd up.
    Once i forgot the firmware after replacing the ssd the device always had a bootloop.
    And check your firmware in Knova. Are the generic brands, (olivetti D-Color, Develop ineo) listed in the compatibility list?
  • Bix
    replied
    Originally posted by occus
    Was it possible to load a firmware after replacement? Try reseat SSD.
    Hi, the printer can only stay on for 2 seconds, so:
    - Unable to log in in service mode.
    - Reset tool does not have time to start.
    - Failed to update firmware.
    Thank you!
  • CP-1015
    replied
    I will be using the firmware of a bizhub C284e. I believe that "plus" corresponds to the "e" series.
    I will let you know
    Yes, it's the C284e.
  • occus
    replied
    2-3 seconds are not enough to see anything meaningful Ed.
  • tsbservice
    replied
    Hi, I have a client with an Olivetti D-color 282Plus.
    The printer keeps restarting every 2-3 seconds. Looks like a bizhub C284e to me. In all likelihood, the SSD no longer works. I tried to detach DF and HDD. Do you think I can insert a new Bizhub C284e SSD?
    Originally posted by emujo2
    Your OP says re-booting..in most cases the re boot occurs after the LCD shows something..Number of fins coming up can help in troubleshooting..So you are saying you power it on and it cycles on/off at this point? E
  • emujo2
    replied
  • Bix
    replied
    if you think it's a 284e how many "fins" pop up before it re boots..and have you tried doing a trouble reset to get to the point where you can enter service mode to check what the error is?
    The printer fails to turn on, so no errors displayed.
    At this point I think PSU or motherboard defective.
