Reboot Olivetti d-Color MF282plus
  • Bix
    • Apr 2018
    • 1421
    Hi, I have a client with an Olivetti D-color 282Plus.
    The printer keeps restarting every 2-3 seconds. Looks like a bizhub C284e to me. In all likelihood, the SSD no longer works. I tried to detach DF and HDD. Do you think I can insert a new Bizhub C284e SSD?
  • GIUBOSS
    • 1437
    Re: Reboot Olivetti d-Color MF282plus
    Try updating the firmware first
    • barber782
      • Aug 2011
      • 286
      Try the Sata controller fw v4 first
      Sent from my VTR-L09 using Tapatalk
      • barber782
        • Aug 2011
        • 286
        And.. You can try usi g the diagnostics screen to see if there's an issue
        • occus
          • 338
          Yes, change the SSD. I replaced a few last year, even with the controller firmware fix installed...
          Sometimes you need a total clear and Moviedata after replacing it, if you get a SSD error.
          • copier tech
            • 8202
            If the machine is on a continual boot loop the SSD has failed & the only option is to replace it.
            You won't get the firmware to update because the machine is continually rebooting.
            Yes you can use a Konica Minolta SSD. (must be new)
            • occus
              • 338
              No, you can use a old one!
              Replace and put in usbstick with newest firmware on first boot. Most time it works, sometimes you need a clear all data.
              • copier tech
                • 8202
                If you use an old one to risk having a counter mismatch error.
                • Bix
                  • Apr 2018
                  • 1421
                  I have ordered a new SSDB.
                  I will be using the firmware of a bizhub C284e. I believe that "plus" corresponds to the "e" series.
                  I will let you know
                  • occus
                    • 338
                    Yes, plus means (e)nhanced.
                    Try the KM fimware, but it happened once that it didn't work, it depends on the firmware version. Then software switch 10 from 04(generic Brand) to 01(KM)
                    • Bix
                      • Apr 2018
                      • 1421
                      Hi, I proceeded like this:
                      - Replaced SSD but keeps restarting.
                      - Removed options but keeps restarting.
                      - RAM removed: MFP stops restarting but nothing comes out on the display. Startup noise only.
                      - RAM replaced unsuccessfully.
                      At this point I am thinking of a broken MFPB. Some idea?
                      • emujo2
                        • Mar 2017
                        • 1579
                        if you think it's a 284e how many "fins" pop up before it re boots..and have you tried doing a trouble reset to get to the point where you can enter service mode to check what the error is?
                        • Bix
                          • Apr 2018
                          • 1421
                          The printer fails to turn on, so no errors displayed.
                          At this point I think PSU or motherboard defective.
                          • emujo2
                            • Mar 2017
                            • 1579
                            Your OP says re-booting..in most cases the re boot occurs after the LCD shows something..Number of fins coming up can help in troubleshooting..So you are saying you power it on and it cycles on/off at this point? E
                            • tsbservice
                              Field tech
                              • 8053
                              2-3 seconds are not enough to see anything meaningful Ed.
