Reboot Olivetti d-Color MF282plus
  • occus
    • 326
    #16
    Re: Reboot Olivetti d-Color MF282plus
    2-3 seconds are not enough to see anything meaningful Ed.
    Was it possible to load a firmware after replacement? Try reseat SSD.
    • CP-1015
      • Nov 2020
      • 298
      #17
      Originally posted by Bix
      I have ordered a new SSDB.
      I will be using the firmware of a bizhub C284e. I believe that "plus" corresponds to the "e" series.
      I will let you know
      Yes, it's the C284e.
      • Bix
        • Apr 2018
        • 1421
        #18
        Hi, the printer can only stay on for 2 seconds, so:
        - Unable to log in in service mode.
        - Reset tool does not have time to start.
        - Failed to update firmware.
        Thank you!
        • occus
          • 326
          #19
          07-SSD-Firmware-Ver6.05m info.pdf
          TNEU1400013EN_SSD board trouble shooting 1.1[1].pdf
          Bix, do you have a new SSD with green Dot? (with 6.05 already installed?)
          Have a look in the troubleshooting guide.
          If you can't install the firmware i think it is not possible to boot a new ssd up.
          Once i forgot the firmware after replacing the ssd the device always had a bootloop.
          And check your firmware in Knova. Are the generic brands, (olivetti D-Color, Develop ineo) listed in the compatibility list?
          • Bix
            • Apr 2018
            • 1421
            #20
            Hello occus, thank you for your reply.
            in germany we are having logistical problems due to bad weather and the parts are arriving late. I have ordered a new SSD which is yet to arrive
            For now I have taken a used SSD to make it stop rebooting. But I have seen that the solution is not effective. The printer keeps restarting anyway.
            Firmware is also unknown. I wanted to try a Konica Minolta firmware because there seems to be no Olivetti firmware on Knova.
            • copier tech
              • 8105
              #21
              You need to fit a NEW SSD.
              • Bix
                • Apr 2018
                • 1421
                #22
                Hi, good news.
                The SSD used was not working but I received the new SSD (identical for Konica Minolta 4e series).
                Now it works again!
                Thank you all for the support.
                Special thanks also to @occus!
                By the way (it has nothing to do with the problem). For those interested: Konica Minolta toners and drums cannot be inserted on this olivetti 282+. it is necessary to make some modifications to the plastics.
                • copier tech
                  • 8105
                  #23
                  Hi, good news.
                  Now it works again!
                  I told you to fit a NEW SSD!
                  • Bix
                    • Apr 2018
                    • 1421
                    #24
                    Yes, I also said a few posts ago.
                    But the weather was bad in Germany, transport slowed down.So in the meantime I had inserted an SSD used to understand if it stopped restarting. But this technique doesn't work.
                    • copier tech
                      • 8105
                      #25
                      No, as I said you can't fit a used SSD for this issue.
                      • Bix
                        • Apr 2018
                        • 1421
                        #26
                        I was hoping it would stop rebooting and return an error with used SSD.
                        I keep learning from mistakes. Thank you.
                        • copier tech
                          • 8105
                          #27
                          Always worth trying used parts but to be honest in my experience you have a much higher success rate fitting brand new parts & often fitting used boards you create more issues.
