bizhub c300i jam tray 1
  • Cantechman
    • Nov 2008
    • 228
    I have a new C300i install with intermittent jam codes 1102 and 1105 from tray 1. Everything related passed the load check. I replaced the whole feed section and it seemed ok temporarily. Any ideas what to try?
  • copier tech
    • 8204
    Re: bizhub c300i jam tray 1
    I assume you have done the basics, like trying a new pack of paper, updating the firmware etc.
    If its a brand new machine pass it back to KM under warranty.
    • Bix
      • Apr 2018
      • 1421
      Where the paper stop?
      • Cidermatt
        • Jan 2018
        • 6
        replace, the reg sensor and put another turn on reg actuator!!
        • Cantechman
          • Nov 2008
          • 228
          Yes did both.
          • Cantechman
            • Nov 2008
            • 228
            I have another complete registration unit to try. It happens intermittently so it's a little difficult to diagnose. If that doesn't work i will try the paper feed roller fast clutch and then finally the base board.
            • Cantechman
              • Nov 2008
              • 228
              [QUOTE=Bix;1680974]Where the paper stop?[/
              Sometimes it doesn't leave the tray, other times it does so no specific place. one or 2 prints seem to be fine it's multiple prints where the issue starts.
              • tsbservice
                Field tech
                • 8056
                [QUOTE=Cantechman;1683731]
                I guess then that will rull out entire registration section. After you replaced whole feed unit does it work?
                • allan
                  RTFM!!
                  • 5462
                  So you say it works just fine with another feeder unit?
                  Whatever
                  • Cantechman
                    • Nov 2008
                    • 228
                    [QUOTE=tsbservice;1683742]
                    it seemed to initially but the customer called back a week later and said it's happening again.
                    • Cantechman
                      • Nov 2008
                      • 228
                      It seemed as though it did for a week or so, must have been a coincedence.
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        make sure its not the cassette itself - i have seen straight out of the box from new damage to the very top edge of the mylar at the rhs of the cassette. Not even visible to the eye but can be felt by the finger nail, and sufficient enough to trap the top sheet feeding out the tray.
                        I've also seen mylars installed crookedly by 1-2mm on the feed unit guides straight out of the factory causing jams too. (tray 2 jams)
                        • Cantechman
                          • Nov 2008
                          • 228
                          The problem was the fast clutch (cl10). It's behind the base board. Once replaced and tested it worked fine.
                          • brent
                            • Nov 2008
                            • 1214
                            cantechman I see the clutch on the diagram and going to order it.. super fun to install? lol since I don't have another machine here in the office to try with
                            until I get the part.. thank you very much for the link you guys are awesome
                            brent
                            • Cantechman
                              • Nov 2008
                              • 228
                              brent
                              It wasn't that bad, the hardest part is just opening up the baseboard box, I'd say start to finish it took 45 min.
