bizhub c300i jam tray 1
  • jwai
    • May 2018
    • 508
    Re: bizhub c300i jam tray 1
    Originally posted by Cantechman
    The problem was the fast clutch (cl10). It's behind the base board. Once replaced and tested it worked fine.
    I wanna ask, what's the function of this fast clutch?
    • allan
      RTFM!!
      • 5462
      I think its to clutch fast.
      Whatever
      • Cantechman
        • Nov 2008
        • 228
        I never really read what it's function is other then helping transport the paper but's only related to tray one and the bypass I do believe.
        • brent
          • Nov 2008
          • 1212
          #19
          It wasn't that bad, the hardest part is just opening up the baseboard box, I'd say start to finish it took 45 min.
          I just received my clutches from km there probaly isnt a procedure in the book I assume? I wish I had another machine in the office to try on first so I don't look like a dork in the customer office.. lol I need to get it on the schedule and get it replaced.. you need to remove the base board is that right?
          thanks brent
          • brent
            • Nov 2008
            • 1212
            #20
            looks not too bad. I hope to get to the customers office next week early.. I will advise.. it is in the manual as well as far as the clutch 10 I didnt see
            it before. but now I do. thanks all
            brent
            • Cantechman
              • Nov 2008
              • 228
              #21
              There is a procedure for that particular clutch in the manual. you have to open the "box" not remove the board itself.
              thanks brent
              • avecosat
                • Jun 2012
                • 304
                #22
                How about the solution? I have the same problem (11-02) in a C250i is the clutch the solution
                • Gift
                  • Mar 2011
                  • 2458
                  #23
                  from my understanding...yes
                    • 22999
                    #24
                    If you read the other posts in this thread you might conclude that CL10 did fix the issue. =^..^=
                      yup reading required
                      • Cantechman
                        • Nov 2008
                        • 228
                        #26
                        Hasn't been issue since it was replaced.
                        • avecosat
                          • Jun 2012
                          • 304
                          #27
                          KM solution for Jam 11-02 , I have tried it and for the moment is work.
                          IMG_20210118_083917.jpgIMG_20210118_083927.jpgIMG_20210118_091228.jpgIMG_20210118_091238.jpg
                          • tsbservice
                            Field tech
                            • 7986
                            #28
                            [ATTACH=CONFIG]49196[/ATTACH][ATTACH=CONFIG]49197[/ATTACH][ATTACH=CONFIG]49198[/ATTACH][ATTACH=CONFIG]49195[/ATTACH]
                            Great, more precise engineering from Konica Minolta
                            • tmmdmmm
                              • Apr 2021
                              • 173
                              #29
                              Not seeing anyone else mention it
                              We've had all our i series come with the Fusing speed maxed on delivery. Dropping it from +7 to 0 stopped intermittent jams from T1 and T2
                              • tsbservice
                                Field tech
                                • 7986
                                #30
                                Good advice although in case of 11-02 jam paper should stop before fuser so fusing speed doesn't matter.
