C454 with Df-624 (not dual scan)
  • lordqpa
    • Oct 2008
    • 22
    [Misc] C454 with Df-624 (not dual scan)
    Hi my friends,
    Does anybody try to install df-624 to c454?
    My df-701 is dead and I'm f for cheaper solution.
  • barber782
    • Aug 2011
    • 286
    Re: C454 with Df-624 (not dual scan)
    Silly question but you did enable it in service mode yea?
    Sent from my VTR-L09 using Tapatalk
    • Bix
      • Apr 2018
      • 1421
      He asked if DF-624 can be installed on C454.
      I honestly have never tried, but it is a curious question.
      In the service mode of C454 settings there is the entry "DF-624". So with a good chance, you can install it.
      • Synthohol
        Certified Konica Expert
        • 5878
        Just remember to remove the dual scan board and select single sided feeder in tech rep.
        • lordqpa
          • Oct 2008
          • 22
          DF-701 dead with C-9403, black (displayport) cable replaced, CIS replaced, small PWB near CIS replaced, suspected DS board.
          Yes, there is the entry DF-624. I'll try and report it ;-)
          Of course, board removed. Now ADF works as platen cover.
          • emujo2
            • Mar 2017
            • 1579
            The DF 701 was the standard ADF on this machine..There were no dual scan feeders until you got to the C652 DS and you do not have the option for selecting which ADF in service mode..IMHO (as I would never even think of trying something like this) unless you can pull the wiring diagrams and be sure that at least the power wiring is the same, you may wind up blowing a power supply by doing this. E
            • Synthohol
              • 5878
              The 652 came with a feeder that's why there is no choice.
              A 454 though you do.
              (it didn't, was thinking the 8 series)
              • emujo2
                • Mar 2017
                • 1579
                Synth I am looking at the installation instructions for the c454..There is no ADF choice for this..It came with the 701 and that's it..I think if you plug in a 624 at best it won't work. The 652 came with a feeder, no choice, the C652 came as single pass or dual scan C652DS, again no choice on the feeders.
                • DelawareJim
                  • Jan 2008
                  • 65
                  Seems to me, a few years ago...we had 3 or 4 that were throwing document feeder codes and it turned out we simply had to re-format the hard drive. I know, I know, it seems a little crazy but it worked. And codes never returned.
                  • tsbservice
                    Field tech
                    • 8041
                    Interesting what codes they were?
                    • Synthohol
                      • 5878
                      my apologies, the 454 is part of the 554 series which yes, only had 1 feeder option.
                      i was thinking the 8 series, the 308 - 558 has 2 choices of ADFs. the 658/758/808/958 had only 1 feeder that came with it.
                      my humble apologies to you and the OP.
                      • emujo2
                        • Mar 2017
                        • 1579
                        no need..you almost had me convinced..I was just trying to keep the OP from throwing a 624 on this machine and possibly blowing it up..I know it's all about saving $$$ but km accessories are not usually able to go from family to family. E
                          • 23010
                          Even when the accessory is mechanically identical, usually the manufacturer makes some software change to make it incompatible. I agree, this could be a costly experiment. =^..^=
