Bizhub only scanning to TIFF
  • Payyyy
    • Feb 2021
    • 4
  • qbert69
    • Mar 2013
    • 1152
    Re: Bizhub only scanning to TIFF
    SCANNING BRAH!!! *NOT* PRINTING!!!
    ...check your linky!!![emoji57]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      your right this was BC (before coffee)
      • Payyyy
        • Feb 2021
        • 4
        Are you telling that setting the scan format to TIFF is going to give us PDF?
        • qbert69
          • Mar 2013
          • 1152
          Choose the settings you like in scan mode then go into system settings->user settings->scan settings ->set current as default (should lock it in...not in front of a machine right now!)
          Good Luck![emoji41][emoji1303]
          • emujo2
            • Mar 2017
            • 1579
            Found this on one of my old "paper brains"
            To default the scan file type to PDF, perform the following:
            1. Press the Utility/Counter button.
            2. Select Check Details.
            3. Enter the Service Mode
            4. Enter the Service passcode and press End.
            5. Select Soft Switch Settings.
            6. Select Mode Selection and enter mode 360.
            7. Select Bit Selection and scroll to Bit 0 and change the value to 1.
            8. Press Set.
            9. Cycle machine main power switch OFF/ON.
            • femaster
              • May 2011
              • 1514
              He's talking a Bizhub 200 here, no such menus or settings existed for at least another 2 to 3 years after the 200 was produced....
              • Oystercopy
                • Oct 2009
                • 623
                I'm going with this idea... it should save whatever settings you have set on the panel.
                • femaster
                  • May 2011
                  • 1514
                  Nope. See my comment right above yours...
                  • tsbservice
                    Field tech
                    • 8020
                    OC, Yes but it works on newer models.
                    • emujo2
                      • Mar 2017
                      • 1579
                      Well you may be correct..I guess the info direct from KM itself is wrong..
                      Related Products:bizhub 200,bizhub 222,bizhub 250,bizhub 282,bizhub 350,bizhub 362
                      Related Options:
                      Question
                      How to default the scan file type to PDF.
                      • Payyyy
                        • Feb 2021
                        • 4
                        8. Press Set.
                        confirmed this is accurate in the service manual... tried it.. still e-mailing TIF
                        • emujo2
                          • Mar 2017
                          • 1579
                          This is a pretty old machine..I have nothing to test with...Any chance the original one touches keep their settings but any new OneTouch would be defaulted to PDF? E
                          • Payyyy
                            • Feb 2021
                            • 4
                            oh no that was it haha feeling really silly right now . Thanks!
                            • femaster
                              • May 2011
                              • 1514
                              Related Options:
                              Question
                              The info in the KB you have indicated is correct:
                              3. Enter the Service Mode.
                              5. Etc...
                              I never stated that the method in your post was wrong. If you look back at my post, you will see that I quoted the incorrect method from another post, not yours. The info I originally quoted and replied to is wrong:
                              "Choose the settings you like in scan mode then go into system settings->user settings->scan settings ->set current as default."
                              That method works perfectly fine on newer models, but on the 200, there was no such menus or settings.
