Bizhub only scanning to TIFF
  • emujo2
    • Mar 2017
    • 1579
    #16
    Re: Bizhub only scanning to TIFF
    Originally posted by femaster
    The info in the KB you have indicated is correct:
    1. Press the Utility/Counter button.
    2. Select Check Details.
    3. Enter the Service Mode.
    4. Enter the Service passcode and press End.
    5. Etc...
    I never stated that the method in your post was wrong. If you look back at my post, you will see that I quoted the incorrect method from another post, not yours. The info I originally quoted and replied to is wrong:
    "Choose the settings you like in scan mode then go into system settings->user settings->scan settings ->set current as default."
    That method works perfectly fine on newer models, but on the 200, there was no such menus or settings.
    Understood..E
