C-368 series, Consumable Life...
  • Oystercopy
    • Oct 2009
    • 623
    I was wondering if there was a way to restore the Consumable Life settings to be viewed on the panel (or in Page Scope) without changing the extended life settings on the machine? It seems that the indicator for consumable life goes away when those settings are changed, so I have no way (that I know of?) of knowing how much Drum Life, Xfer Belt Life, etc. the machine has...
    Thanks in advance!
    OC
    • 23008
    Re: C-368 series, Consumable Life...
    You can look in service mode > Life or just print off the Management List. Most of those consumables, the yield is measured in minutes of rotation time, not prints. The details are in the manual. =^..^=
    • Synthohol
      Certified Konica Expert
      • 5824
      bit switch 227 change from hex 80 to hex 00 and hit fix. then #5 check consumable levels will be available on the 4 and 8 series.
      same bit switch and hex for the i series but its viewed where you see the toner levels, you have to scroll.
