Bizhuib C258, missing network.
  • Savian
    • Feb 2021
    • 14
    Hi.
    My BZ C258 just missed network configuration. Option Network Config does not appear in the Administrator tab or in the service menu. What can I do?
  • copier tech
    • 8174
    Re: Bizhuib C258, missing network.
    Originally posted by Savian
    Hi.
    Shut the machine down & unplug the LAN cable then power back on.
    Sometimes the network setting page takes a while to appear.
    • Savian
      • Feb 2021
      • 14
      Nothing.
      I was performing a Clear Network Data in service Mode when a energy blackout happend.
      • copier tech
        • 8174
        Nothing.
        That was unlucky timing.
        Update the firmware & try all ‘all clear’ in CE mode.
        • tsbservice
          Field tech
          • 8020
          Nothing.
          You should start with this. Why not mentioned such a critical information?
          • Savian
            • Feb 2021
            • 14
            • Savian
              • Feb 2021
              • 14
              • tsbservice
                Field tech
                • 8020
                If you have difficulty to update FW try firstly doing Initialize All. Depends on what data is corrupt may help.
                • Savian
                  • Feb 2021
                  • 14
                  Do you mean Clear all data?
                  • tsbservice
                    Field tech
                    • 8020
                    Yes.
                    • Synthohol
                      Certified Konica Expert
                      • 5849
                      You will need movie data and re-enable the hdd following the all clear.
                      I can help with that if you need.
                      • tsbservice
                        Field tech
                        • 8020
                        Synt is always coming to help and more. My bad didn't mentioned this.
                        • Savian
                          • Feb 2021
                          • 14
                          Sure, any help will be welcome.
                          • Savian
                            • Feb 2021
                            • 14
                            Relax, I am sure you would do it next.
                            • Synthohol
                              • 5849
                              check your PMs.
                              please consider becoming a contributor.
                              https://www.copytechnet.com/forums/v....php?do=donate
                              thanks.
