install EM907 on C227i / C257i / C287i
  • jwai
    • May 2018
    • 509
    Hello,
    It's necessary to upload firmware after install the EM907 extended memory unit?
    Best regards,
  • tsbservice
    Field tech
    • 8020
    Re: install EM907 on C227i / C257i / C287i
    Originally posted by jwai
    Hello,
    Best regards,
    I really don't know but it would be only good to update machine firmware to the latest.
    • Synthohol
      Certified Konica Expert
      • 5847
      When adding accessories it's a good idea to run firmware anyway so you are assured all the components are on the same page. (Pun semi intended)
      • copier tech
        • 8174
        This is good practice & should you need the latest & greatest drop us an email.
        Firmware Update - Printer & Copier Firmware
        • jwai
          • May 2018
          • 509
          Thank you very much !!
