Why can some computers use the name for SMB while others need the IP
  • adecanmin
    • Oct 2010
    • 316
    I could never figure it out. I was setting up a Konica Minolta to scan. Two machines in the same office. One I was able to use the computer name (preferred) and the other I had to use to IP. Is there a setting in the computer I need to change? I looked at the hosts file but it looked the same on both machines.
    Re: Why can some computers use the name for SMB while others need the IP
    what OS on each puter?
    are they on the same ip scheme?
    what are the settings for each one of the copiers?
    little info given.
      • 23008
      Maybe someone will correct me on this, but I have always assumed that issues with host name resolution originate at the DNS server. =^..^=
      • Santander
        • May 2009
        • 768
        Are both machines on the same IP segment? Just because they are in the same office does not mean they are on the same segment or the same router. Using the computer name requires that a DNS server has the computer name mapped to an IP address. You could also experience a problem using the computer name if the domain name is not registered in the machine and does not send the computer name to the domain DNS server. Are both machines the same model?
        A couple of questions:
        1. Are both computers running the same version of the OS?
        2. Is network discovery enabled on both computers?
        3. Are both computers set to private network? A computer set to public will not allow a connection as it is not discoverable on the network but will work with the IP address.
        4. Are both machines running the latest firmware? Recent changes in Windows updates have changed the SMB protocol so older versions of firmware do not work.
        5. What SMB protocol version is enabled on each unit? SMB v1 will not work on later windows systems.
        Hope this helps in getting started in the right direction.
        • adecanmin
          • Oct 2010
          • 316
          Thanks for the responses. My original post looked as though it was 2 copiers. It is one copier, a c3850 that will scan SMB 2.0. The computers in question are a Dell and an HP. They are both windows 10. I don't know what version of 10 they are running. I'm assuming the copier is configured properly since one computer will receive scans using the name. I have another customer with the same scenario. One copier, some machines (windows 10) will scan using the name while others can't. They are on the same network. With this customer I was able to get into the router and configure a DHCP reservation for the computer. More times then not the customer does not have the password to the router so I can't get in there to give the computer a static DHCP reservation.
          • rrrohan
            • Sep 2011
            • 1977
            is LLMNR enabled on the copier?
            • adecanmin
              • Oct 2010
              • 316
              Not sure. I can check that next time I'm there. I checked my personal c3850 and it is enabled. I'm thinking it is enabled by default.
                • 16395
                That's where he needs to start. I'd do a NSLOOKUP followed by followed by the IP address of the copier. Exp.: NSLOOKUP 192.162.1.150.
                If everything is working correctly, it should return the IP address of the copier and the hostname.
                  • 30235
                  You can try and disable ipv6 on the nic of the PC than it will only use ipv4
                  • adecanmin
                    • Oct 2010
                    • 316
                    I'll check those things.
                      • 16395
                      You can also try to flush DNS.
                      ipconfig/flushdns
                        • 37503
                        NetBios name resolution is based on Workgroup/Domain membership and primary DNS. Check those settings on the computer that you can scan to using its name and change the other to match.
                        • adecanmin
                          • Oct 2010
                          • 316
                          Where would I look to find those settings?
                          • adecanmin
                            • Oct 2010
                            • 316
                            This particular network is a WORKGROUP
                              that info should have been shared about 15 messages ago.
