Why can some computers use the name for SMB while others need the IP
  • adecanmin
    • Oct 2010
    • 291
    #31
    Re: Why can some computers use the name for SMB while others need the IP
    I have some customers with older machines that I use FTP. A have a handful that I can use the hostname but most is IP. I'll use these recommendations to hopefully resolve this as well.
      • 37301
      #32
      Originally posted by adecanmin
      EDIT: I recommend this as a last resort because it could cause a problem if/when the copier is removed from the network. That IP address will be permanently resolved to the hostname of the copier until it's deleted from the host file.
      I'll try that, thanks. It is an issue I've been dealing with on and off for years. I don't mind deleting the information in the hosts file if the copier is replaced down the road if this works. I'll also to check to see if it is private network.
      One huge problem with trying to edit the computer's hosts file. It does nothing to help the copier find the computer. Now if there is a hosts file on the copier and if you can edit it.....
        You're right. It's not gonna do a thing to help the copier find the PC. From my understanding, he's having no problem with communication between the PC and copier as long as he's using the IP address. The problem is when he tries to use the hostname that he loses communication.
        If I remember correctly, and I think I do, when an entry is made in the host file for the PC with the copier's IP address, the PC will look there first before trying to look at DNS cache or router.
        The problem with that is, if the host name is ever changed, the PC will still link that IP address to the old host name. I did this by accident when I was playing around with it.
          • 37301
          #34
          You're right. It's not gonna do a thing to help the copier find the PC. From my understanding, he's having no problem with ommunication between the PC and copier as long as he's using the IP address The problem is when he tries to use the hostname that he loses communication.
          Another problem is when the network itself is changed. I have had instances where the customer has changed their ISP or had to replace cable/dsl modem. If they are using the modem for DHCP then the entire local network can change. Like from 192.168.1.xxx to maybe 192.168.3.xxx or maybe even to a different class of network.
            • 29854
            #35
            Wrong information as ALWAYS
            Basic networking
            Hostname Resolution refers to the process through which an assigned hostname is converted or resolved to its mapped IP Address so that networked hosts can communicate with each other.
              • 37301
              #36
              Basic networking
              And in the case of scan to SMB is accomplished through DNS
              • rrrohan
                • Sep 2011
                • 1977
                #37
                Originally posted by emujo2
                Add a global DNS server if possible, 8.8.8.8.
                External DNS will do nothing to help resolve local network host names
                Sent from my Pixel 4 XL using Tapatalk
                  This is true. External DNS deals with the internet. A local DNS resolver has to do the the Intranet.
                  • adecanmin
                    • Oct 2010
                    • 291
                    #39
                    I went to a c3850 the other day I could not get it to scan smb 2.0 using the computer name in a workgroup for the longest time. I tried using the name this time and now it works. I did nothing to the computer aside from using the name. I had another that was on a public network and it worked using the computer name. I'm gathering there is no definitive answer as to why some can scan using the name while others need an IP in the same office. I'll keep looking for a solution.
                    • emujo2
                      • Mar 2017
                      • 1580
                      #40
                      Some times the answer is poor network mgmnt due to a lack of or little care about the network. When Joe from the church is the "network' guy, you can bet he's going to blame the machine. These guys will add equipment, change routers and ISP without any regard to the problems they will induce..Then they expect the copier repair guy to work it out. Sometimes you just want to say..use the scan to usb thumb drive, I'm done with you. E
                      • adecanmin
                        • Oct 2010
                        • 291
                        #41
                        That is true.
