C759/C659 noise
  • jwai
    • May 2018
    • 509
    C759/C659 noise
    Hello,
    Do everybody have experience sometimes the noise is occurred on this machine.
    I checked the fusing unit and exit section, added lubricant.
    However the customer reported the same issue, the meter is below 70K.
    Any suggestion?
  • Bix
    • Apr 2018
    • 1421
    Re: C759/C659 noise
    Hi,what kind of noises do you hear (metallic or plasticky)?
    Does it often happen when it is not used for a long time?
    • jwai
      • May 2018
      • 509
      Re: C759/C659 noise
      They called these 3 days and only can hear on the first time, like a squeaking sound but very light volume.
      They said it would be happened usually on idle status, 2-4 times each day.
      • Synthohol
        Certified Konica Expert
        • 5849
        Re: C759/C659 noise
        Turn off sleep mode and make the energy save 5 minutes.
        This prevents the oil roller in the fuser from drying out too fast causing 80% of all squeals squeaks and clicking.
        Just my .02.
        • jwai
          • May 2018
          • 509
          Re: C759/C659 noise
          Just my .02.
          Thank you, let's try.
