PDF/A
+ More Options
Posts
  • jwai
    • May 2018
    • 508
    PDF/A
    Hello,
    Do everyone supply the PDF/A font zip file for the C287i series? Thank you very much.
  • Synthohol
    Certified Konica Expert
    • 5832
    Re: PDF/A
    ck PMs
    • Synthohol
      • 5832
      Re: PDF/A
      Did not see the "i"
      I can help tonight when I get home.
      My bad.
      • tsbservice
        Field tech
        • 8019
        Re: PDF/A
        Originally posted by Synthohol
        Did not see the "i"
        My bad.
        You can always use this
        • Synthohol
          • 5832
          Re: PDF/A
          wow, that model is not available in the USA so there is no file to download.
          unless there is a US model that will work?
          sorry, i tried.
          what does the firmware start with? like "AA2J0Y0".
          i may find one that works on a US model but i need more info.
          • copier tech
            • 8164
            Re: PDF/A
            Originally posted by jwai
            Hello,
            Happy to help, contact us below should you still require this file.
            Firmware Update - Printer & Copier Firmware
            โ€‹
            • rrrohan
              • Sep 2011
              • 1977
              Re: PDF/A
              id help but i also dont see a C287i in kangaroo country neither
              • tsbservice
                Field tech
                • 8019
                Re: PDF/A
                Bizhub C227i_C257i_C287i same series. Some of them may be market depending.
                • jwai
                  • May 2018
                  • 508
                  Re: PDF/A
                  Exactly !
                  • jwai
                    • May 2018
                    • 508
                    Re: PDF/A
                    Did not see the "i"
                    My bad.
                    Thanks a lot.
                    • Synthohol
                      • 5832
                      Re: PDF/A
                      Bizhub C227i_C257i_C287i are not in the US market and are unavailable on this side of the pond.
                      sorry.
                      • jwai
                        • May 2018
                        • 508
                        Re: PDF/A
                        sorry.
                        Never mind Synthohol.
                        • rrrohan
                          • Sep 2011
                          • 1977
                          Re: PDF/A
                          I hope the i series is a improvement over the non i
                          Sent from my Pixel 4 XL using Tapatalk
                          • ServiceMan79
                            • Jan 2020
                            • 1
                            Re: PDF/A
                            Can I ask for help with the PDF / A Font file for the Bizhub C454e machine (I formatted the disk and the file is lost)
                            • techsxge
                              • Jan 2022
                              • 660
                              Re: PDF/A
                              Originally posted by SamHanson
                              Guys, hello! If you also work with PDF documents, then I am sure that you, like me, often need convenient tools to edit PDF files. In fact, everything can be found online, for example, I like this tool on the PandaDoc website, with which I can easily merge several PDF pages into one file for free, so try it.
                              PDF24 is also free and has more functions than yours
