C258 alternative bypass rollers?
  • barber782
    • Aug 2011
    • 286
    Hi everyone,
    Just out of curiosity, has anyone ever used an alternative feed roller for the bypass? (as unofficial mod) to see if it improves the paper feed.
    Sent from my VTR-L09 using Tapatalk
  • GIUBOSS
    • 1437
    Re: C258 alternative bypass rollers?
    Originally posted by barber782
    Hi everyone,
    I happen to replace the rubber rollers of the drawers or the bypass with other brands but only if very similar and in any case then in the long run they gave problems, much better the originals, however I noticed that the pickups with toothed tread take better any type of paper
    • copier tech
      • 8235
      Hi everyone,
      Never really had an issue with KM bypass feed. I do have a few clients who feed a lot of pre-printed letterhead, this rubs off onto the feed causing pick up issues. However I simply show them how to clean the feed roller & I never hear back.
      • allan
        RTFM!!
        • 5462
        Some glossy and other special paper stock tend to have lots of paper dust on them. Cleaning regularly is my only advise.
        Whatever
        • tsbservice
          Field tech
          • 8076
          Yepp, paper bits tend to adhere to rollers. Simple cleaning will help tremendously.
          • copier tech
            • 8235
            Exactly, did you read previous posts!?
            • barber782
              • Aug 2011
              • 286
              Cleaning does help but only for about a week. Might just be the paper it doesn't like tbh.
