Konica Minolta C454e Missing Image - Jpeg
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C454e Missing Image - Jpeg
    Hi
    Konica Minolta C454e When client prints Photos/Files Specially JPG using any software (Windows Photo Viewer, Paint etc.) Print is missing from the middle. From all of his computers.
    Updated the firmware G20-M1, Replaced the driver.
    Normal print is fine.
    Please find the attached and advise.
    Many Thanks
    mearmi
  • Synthohol
    Certified Konica Expert
    • 5866
    Re: Konica Minolta C454e Missing Image - Jpeg
    what happens from your laptop?
    what happens printing from usb?
    • mearmi
      • Oct 2010
      • 350
      From Laptop it is same as other computers.
      Didn't try USB.
      • tsbservice
        Field tech
        • 8031
        @mearmi - try Initialize All.
        • ltdiniz
          Supervisor de Campo
          • Mar 2021
          • 98
          Atualizacao de marco do Windows 10 causa problema com o uso de impressoras | Mundo Conectado
            • 23010
            We've seen distorted images from Windows Picture & Fax Viewer for the last 4 years or more. My suggestion is to use another JPG viewer, and it always works. A favorite is Irfanview. It's free, and has a LOT of features that your Windows Picture & Fax Viewer does not.
            Download IrfanView
            • allan
              RTFM!!
              • 5462
              Internal prints like demo page printing ok?
              Whatever
              • vikashkj
                • Feb 2021
                • 6
                Originally posted by mearmi
                Hi
                Many Thanks
                mearmi
                I am too Facing the same issue.
                i think the issue started with the latest windows 10 update
                if any one has solved it. please help
                • emujo2
                  • Mar 2017
                  • 1579
                  There are many fonts that the printer does not understand. If you are using the PCL driver try "print as image" to see if this resolves it..The driver also allows you to choose not to use printer installed fonts..This may help as well. E
                  • tech51
                    • 846
                    • mearmi
                      • Oct 2010
                      • 350
                      Yes It is fine
                      • mearmi
                        • Oct 2010
                        • 350
                        Didn't work
                        • kaisa
                          • Sep 2019
                          • 9
                          remove Windows Update KB5000802
                          • jwai
                            • May 2018
                            • 516
                            Yes ! this issue is being happened this month.
                            Some PC the update maybe KB5000808 or KB5000809.
                            • JOHNR
                              • Jan 2021
                              • 9
                              Hi
                              Many Thanks
                              mearmi
                              I had the same problem.It was a new security windows update that was causing the problem.I went to start ,then settings and then update and security.then windows update and history of updates.then click on the last update for windows security and erase it.The pc will rebout and the problem will be fixed hopefully.It work for me,i hope will work for you too.
