C450i - IC420 and initial setup
  • copytechman
    • Nov 2008
    • 969
    Hope for a little insight.. .have setup the device according to the books. Fiery is live via web interface and have enabled the web browser, however touching the fiery button does nothing, also the web browser is still grayed out despite being enable...
    What am i missing here?
    Help please!
    A.
    I thought I enabled the web browser with function code B, via the LMS tool but it still doesnt show up as function (besides the grayed out thing).
    when I went to the LMS tool I entered the device sn and the choice it gave me was the web browser with a function code b and license...
    when entered the device rebooted to no apparent change... I think im still missing something... anyone?
  • emujo2
    • Mar 2017
    • 1579
    Re: C450i - IC420 and initial setup
    Service mode system 1 controller set to 1 (just double check)..VI kit installed correctly and cables connected...Web Browser enabled ( admin/network web browser)
    Power off controller, then MFP..let sit for a few min..Power up controller, give at least 5 min once you see 00.. next power up MFP and WAIT!!! I cannot stress the waiting part..It can take 30 min for the controller to come to ready the 1st time..it should print a config sheet when it's darn good and ready to move along..E
    • copytechman
      • Nov 2008
      • 969
      • Synthohol
        Certified Konica Expert
        • 5905
        You need to disconnect the fiery, set to controller 0 in service, enter in working IP info including DNS and activate the web browser in admin mode.
        If the machine does not have the extra memory to enable the web browser that may be the issue too.
        • copytechman
          • Nov 2008
          • 969
          Ok , was going to try that next after a mem clear , extra memory is needed even with the uk-kit u need to install the fiery ?
          regards !
          a.
          I will check to see in my price book if additional memory is needed to enable the browser despite the addition of the uk kit which is needed in addition to the vi kit to make the fiery work.
          Regards!
          A.
          • strider5555
            • Jun 2008
            • 96
            Just to be clear. You enabled the web browser function on the machine from the admin menu first before doing anything else. From panel or web browser, log in as administrator, go to network>web browser>web browser and turn on the radio dial. Then you installed the UK 115 which is required for c450i, then the VI 516 video interface. Then install the Fiery and configure either in A or B setup.
            Here is the install guide just in case.
            • tsbservice
              Field tech
              • 8064
              regards !
              a.
              Regards!
              A.
              No need of extra memory for web browser just see if it's enabled by default from admin menu.
              Those machines come ready to shoot like machine gun, very fast hardware but software...at times is just embarrassing.
              • copytechman
                • Nov 2008
                • 969
                Well no I didn’t , I followed the install guide , connected it all as a b setup , attempted to enable the browser which didn’t do anything it seems . At which point I connected the machine right to the normal (not fiery ) connection to our network, rebooted and it got a local ip on the normal controller , (controller tho was still set to controller 1 ) nothing changed , at which point I said to heck with this , did a memory clear so I could basically start fresh with network plugged into normal instead of the fiery . I haven’t got a lot farther with it since was gonna tackle it anew tomorrow, I suspect that once the browser function works that the fiery button will too . (It lit up it just didn’t do anything , I could access the fiery from the web side tho)
                regards!
                A.
                As a side note , this is the first fiery I have setup that has had to have the browser enabled on the device first for it work. Have setup tons of fierys , just not this specific model.. yet .
                • tsbservice
                  Field tech
                  • 8064
                  • copytechman
                    • Nov 2008
                    • 969
                    • Synthohol
                      • 5905
                      Yes step 4 in the install guide has you enabling web browser before even taking off a cover to install VI.
                      The 4 series was the same deal, web browser is always 1st.
                      The 3 series and before didn't matter it was a different breed
                      • copytechman
                        • Nov 2008
                        • 969
                        • emujo2
                          • Mar 2017
                          • 1579
                          yes, step 4 does say the web browser must be enabled, but pretty sure this does not mean "go no further until web browser works". Greyed out web browser should mean this function is installed but not activated..(you could type the s/n into LMS to determine if it's activated, and admin network settings to enable the function. There are some weird things that happen when your function version and firmware are not matching..you may want to discount double check this as well. E
                          • copytechman
                            • Nov 2008
                            • 969
                            • copytechman
                              • Nov 2008
                              • 969
                              UPDATE:
                              A soecial nod to Emujo (I hope I spelt that correctly).. So aside from the browser thing it turns out that the machine won't let you do anything without the toners in it (I was awaiting those for initial setup) Once those were installed, everything started working. (I normally have the toners on setup and this is the first time in a long time that I hadn't).
                              So tyvm for all of your assistance its all good now!
                              Regards!
                              A.
