service mode C364e
  • SID Copy
    • Jan 2021
    • 3
    service mode C364e
    Good afternoon friends, if you can support me, I have a Konica C364e that I need to enter the service mode, but they changed the password, someone who can support me on how to unlock and be able to enter the service mode, Thank you
  • copyman
    Owner / Technician
    • Sep 2005
    • 4684
    Re: service mode C364e
    Have you tried all the usual password combinations?
    9272927292729272
    92729272
    12345678
    1234567812345678
    00000000
    If none of these work then think there is a reset firmware you will need.
    • SID Copy
      • Jan 2021
      • 3
      Good mornig, if I already providell all those key combinations and did not accept any, you have the firmware for rebooting since I did not find one for this equipment
      • copier tech
        • 8142
        You will need the NVRam firmware to reset the CE password.
        Contact us below should you need this.
        Firmware Update - Printer & Copier Firmware
        • SID Copy
          • Jan 2021
          • 3
          the firmware of the NVRAM for the model C364e I was looking for it on the page and it does not come, in the model C360 if it brought the firmware of the NVRAM, you have the firmware of the NVRAM for the C364e
          • copier tech
            • 8142
            Yes, we can supply what ever model you require.
            • Walterj
              KONICA MINOLTA
              • Jun 2017
              • 89
              • Walterj
                KONICA MINOLTA
                • Jun 2017
                • 89
                These machine models have SSD not NVRAM.
                And to solve this problem is not only to rewrite the FW.
                • copier tech
                  • 8142
                  I'm referring to the reset tool, some call it NVRam firmware reset etc.
                  NVRam reset tool.pdf
                  • Max
                    • Oct 2011
                    • 557
                    Try reset option in pagescope. I assume admin password for pagescope hasn't been changed.
                    • tsbservice
                      Field tech
                      • 8008
                      So admin can reset CE password? I always thought about it other way, please enlighten.
                      • Max
                        • Oct 2011
                        • 557
                        Reset option under service tab I think it is.
                        • copier tech
                          • 8142
                          No. You can only reset/change the CE password from CE mode.
                          & without knowing the CE password this makes it difficult.
                          • tsbservice
                            Field tech
                            • 8008
                            That was Rhetorical question.
