tape problem on PC417
  • cHm
    • Mar 2021
    • 6
    hello I allow myself to create a new thread because I have a problem on two pc417 modules, tray number 3 create jams on two identical copier a bizhub c450i I change the 2 modules but the two new ones do exactly the same thing I changed the paper plugs, changed the sensor, I ran out of ideas
  • cHm
    • Mar 2021
    • 6
    Re: tape problem on PC417
      • 14707
      What jam code is being generated?
      Where is the paper stopping?
      Are there any nicks, or paper being crumpled?
      • Albonline
        • Sep 2008
        • 1150
        [ATTACH=CONFIG]48699[/ATTACH][ATTACH=CONFIG]48699[/ATTACH]
        cause of this is lack of or insufficient pressure on those two white rollers in the photo. The df torque limiter in this system is really tight.
        • Synthohol
          Certified Konica Expert
          • 5823
          JAM CODE?
          • cHm
            • Mar 2021
            • 6
            hello how to fix this ?
            • cHm
              • Mar 2021
              • 6
              • Synthohol
                • 5823
                without revealing the actual jam code is like going to the dentist but wont tell them which tooth hurts.
                help US to help YOU.
                photos are irrelevant without the jam code.
                wheres the "dentist"? lol
                • Albonline
                  • Sep 2008
                  • 1150
                  i push down on the ends of metal bracket holding the rollers. deforming enough to apply a bit more pressure. have fixed dozens of these doing only that. if you have been putting your fingers all over the feed tire system i would also clean with ipa.
                  • mojorolla
                    The Wolf
                    • 2608
                    Did you configure the LCT (go into Service Mode, System 2, LCT and set the paper sizes) ?
                    • Gift
                      • Mar 2011
                      • 2459
                      +1 for the bracket adjustment, we also had some PC417 jamming directly out of the box
                      • cHm
                        • Mar 2021
                        • 6
                        • cHm
                          • Mar 2021
                          • 6
                          thank you to all the problem is located at the level of the white pressure roller, the problem was quickly resolved with your valuable advice
                          • tsbservice
                            Field tech
                            • 8008
                            You don't need our friend to pull some tooths when Zen-Uber KM master speaks
