Konica 951 dev come with copy
  • DoctorEv
    • 6
  • allan
    RTFM!!
    • 5462
    Re: Konica 951 dev come with copy
    Try switching off the drum potential sensor. SW 6 bit 7. Just an idea. Not sure what that can do to the charge value if its faulty.
    Whatever
    • lartis.aineias
      • 78
      Try to change HV1
      I had same problem. I solved with HV1
      Στάλθηκε από το SM-G975F μου χρησιμοποιώντας Tapatalk
      • copier tech
        • 8142
        Strip & clean all the contacts, blow out all stray toner & developer this may help stray dev causes shorts.
        • DoctorEv
          • 6
          Thank you!! I will try all advices and last, HV1)) because it's very difficult. 5 wires go inside of machine without connectors;(
          • DoctorEv
            • 6
            Thank you!
            • DoctorEv
              • 6
              Originally posted by lartis.aineias
              Try to change HV1
              Thanks, I will try!
              • DoctorEv
                • 6
                Ok Thanks! I will tray !
                • apostlegato
                  • Oct 2020
                  • 12
                  951 has a transfer belt?!? Oh the days when you could just turn the light off in the room open the door and key the door switch and watch for the arcing. I am surprised, I assumed the high volume monochrome machines would still have corona wires.
                  • DoctorEv
                    • 6
                    You can check SM
