minolta uneven color on cyan
  • Rigabula
    • Sep 2015
    • 16
    hi all, we have minolta c452 that started printing with faded top of the page. Replaced drum, developer, corona but the problem remains. Attaching pics of the print any ideas
    Re: minolta uneven color on cyan
    transfer roller
    as long as it isn't running crap non-oem toner
    • tsbservice
      Field tech
      • 8053
      Post CMYK halftone patterns not this mixed colors. This is old model what about counters - total and parts?
      • Synthohol
        Certified Konica Expert
        • 5892
        check the rear transfer roller pressure cam spring post, it might be broken.
        • mascan42
          • Oct 2008
          • 485
          Is it only cyan? If so, the only thing remaining that's color specific would be either the print head or bias voltage.
          • allan
            RTFM!!
            • 5462
            Could be the cyan primary transfer roller that does not get proper contact. Could be your ITBU.
            Try transfer voltage adjustment in service mode.
            Whatever
            • copier tech
              • 8202
              If its only on cyan after you rebuild the image unit?
              Fit a new genuine cyan image unit & genuine toner.
              • allan
                RTFM!!
                • 5462
                If you rebuilt it and that happen just after that then its not assembled correctly or its missing something.
                You can change out the colors to test please don't mix the toners.
                Whatever
                • Rigabula
                  • Sep 2015
                  • 16
                  It is only Cyan other colors print fine might be voltage but not sure how to check it. Swaped another unit same problem. Machine runs on original supplies. Just opened a new toner to see if that changes anything. The other IU now has the same problem on another machine ?? Both units are OEM
                  • Rigabula
                    • Sep 2015
                    • 16
                    Problem is at the top of page halftone doesn show this problem because of the location 10% - 30% cyan is the best way to see any defects at any color . It shifts along the page and the green print is baceuse it matches when mixed with Y the color problem is more noticable because of that
                    • Synthohol
                      • 5892
                      have you cleaned off the lasers? ran a skew reset? pulled out the transfer belt and make sure the 1st transfer rollers drop down properly?
