4/4e series paper size on tray
  • jwai
    • May 2018
    • 502
    Hello,
    I found the bizhub 4/4e series have common issue below:
    The tray 1 often have auto paper size detection error, place A4-> display 8 1/2" x 11" , place A3 -> display 11" x 17".
    I tried to test the paper size detection sensors by exchanging them with tray 2 however the same result occurred.
    Have any idea about this?
  • copier tech
    • 8100
    Re: 4/4e series paper size on tray
    Originally posted by jwai
    Hello,
    This is a know issue, the wire on the connector breaks, you need to replace the small loom.
    • Synthohol
      Certified Konica Expert
      • 5735
      Could it also be the marketing area is not set correctly?
      • jwai
        • May 2018
        • 502
        the 4 yellow wires of the sensor on the middle of the cassette section?
        • jwai
          • May 2018
          • 502
          They are " others 2 " on marketing area.
          I found it is only happened on tray 1, tray 2 never.
          • copier tech
            • 8100
            Yes.
            • jwai
              • May 2018
              • 502
              Yes.
              Thank you,
              can't imagine these wires would be broken without impact.
                Thank you,
                or somebody not pulling the connector properly .. never remove a connector by grabbing just the wire harness
                • jwai
                  • May 2018
                  • 502
                  I checked the connectors and 2 wires loosened,
                  it seems nothing happened on 8 series.
                  • Toxic
                    • 694
                    Probably because most users use tray 1 more often.
                    I have only 1 case and it happened because user do very much id card copy but they copy one side then put back paper to tray 1 and copy 2nd id card side
                    Too much open-close tray will over time damage this wires.
                    • tsbservice
                      Field tech
                      • 7909
                      Then you can go and setup for their convenience copy settings for printing ID cards directly without this archaic paper rotation
                      • jwai
                        • May 2018
                        • 502
                        Maybe the cause that I guess:
                        The CD sensor holder is set on one screw with spring, can slide front and back a bit distance.
                        But, the harness is installed so tight on the bracket, that yellow wires are easily to tear off.
                        • copier tech
                          • 8100
                          Yes, exactly this. When installed at the factory there was not enough play in the cable plus the cable ties were too tight.
                          • Toxic
                            • 694
                            Few years ago i sold them C227 and take that C224e (count as few hundred $), soldered few broken wires of paper sensors and lease that machine, still going strong.
                            Ofcourse i show them how to copy id card in proper way, without need to put paper back to tray for second side
                            • tsbservice
                              Field tech
                              • 7909
                              C224e over C227 all day long
                              I'm guessing those clients are too stuborn to learn something new I have many of them and sometimes they really deserve what they have.
