Missing - Bypass tray overwrite settings for print PC
  • tmmdmmm
    • Apr 2021
    • 173
    [Misc] Missing - Bypass tray overwrite settings for print PC
    Hello all!
    I was at a call earlier and a customers program would only print envelopes as Paper Type: Plain over Paper Type: Envelope. Other programs had the right type.
    I had read about "Bypass tray overwrite settings for print PC", and it should be in Admin>System.
    Could not find it on the MFP nor signed into admin on web connection, same with the rest of my calls for the day.
    Does anyone know of a setting that could be conflicting?
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: Missing - Bypass tray overwrite settings for print PC
    knowing the model may help a bit.
    • rrrohan
      • Sep 2011
      • 1977
      You didn't mention the model but from memory it's only a feature on 8 series and on
      Sent from my Pixel 4 XL using Tapatalk
        • 23008
        What application are you using. Are you defining both paper size: COM10, and media type: envelope in the application?
        • tmmdmmm
          • Apr 2021
          • 173
          thanks! My bad, thought I had mentioned it was a 4 series, and looking at my log so were the rest of the ones I checked that day
