C550i f/w update
  • Max
    • Oct 2011
    • 555
    C550i f/w update
    Hi. Various post about F/W not updating/ not booting up. Is it the memory board (the one with the heatsink) or the rectangle storage board that is fixed by one screw that needs replacing? Wanted to double check before I start ordering bits.
    Run a diagnostic tool too, dont quite see the purpose of it as it always reports pass/Ok on everything.
    Also tried different usb sticks and different lvl of firmware including individual option update. Same result NG.
    Thank you.
  • copier tech
    • 8138
    Re: C550i f/w update
    Thank you.
    The diagnostic tool passes because there are no hardware issues, only software (firmware) Did you try the latest GC2-G4 ?
    C550i C650i Firmware Readme GC2-G4.pdf
    • Max
      • Oct 2011
      • 555
      Yes I did. No Joy.
      • copier tech
        • 8138
        Yes I did. No Joy.
        Did the update complete or still stick at 25% ?
        • Max
          • Oct 2011
          • 555
          Fails every time at different percentage. Does it have to be a konica storage or can it be an off the shelf ssd?
          • tsbservice
            Field tech
            • 8003
            .... Does it have to be a konica storage or can it be an off the shelf ssd?
            That is the real question. New SB from KonMin will solve your problem but if no warranty they're somewhat pricey
            Machine not taking FW or stuck at 25% boot I believe are symptoms of corrupt FW on SSD.
            So far they seems rarely failed hardware but after blackout maybe some bits/parts of memory are damaged thus no boot or MFP - N.G. in firmware update.
            • Max
              • Oct 2011
              • 555
              Update. Managed to recover original memory board using a M2 USB adapter by formatting and deleting partitions and using USB reset What a pain.
              • avecosat
                • Jun 2012
                • 305
                How did you do it ? You have formatted the SSD with the adapter and then you have booted the machine with the recovery USB. Thank you
                • mojorolla
                  The Wolf
                  • 2604
                  This is a known issues and recently updated in the Solutions pdf:
                  Updated: 3/12/2021
