Bizhub 458
  • afterhours
    • Mar 2017
    • 152
    Bizhub 458
    Hi everyone. I have a customer with a Bizhub 458 with a LCT large capacity tray 3. Every time the machine feeds out of tray 3 we either get a wrong paper size error or jam 99-01. We ended up swapping the LCT but its still doing the same exact thing.
    Any help will be appreciated.
    Im a Loser Baby!!!
  • tsbservice
    Field tech
    • 8064
    Re: Bizhub 458
    This is from machine setup?
    • Max
      • Oct 2011
      • 569
      Re: Bizhub 458
      There should be a paper size option for lct in service mode. Or sticky/dirty sensor perhaps.
      • afterhours
        • Mar 2017
        • 152
        Re: Bizhub 458
        This is a used machine at the customers office. Paper path is clean. Sensors have been checked.
        Sent from my SM-G981U using Tapatalk
        Im a Loser Baby!!!
        • afterhours
          • Mar 2017
          • 152
          Re: Bizhub 458
          I checked the paper size option for the lct and it is correct.
          Im a Loser Baby!!!
            • 15017
            Re: Bizhub 458
            If this is the LCT that sits under the machine check the yellow paper separator guide and be sure it moves freely
            • emujo2
              • Mar 2017
              • 1579
              Re: Bizhub 458
              Be sure that the marketing area is set correctly, the size setting of the LCT is correct LT for US markets. Firmware and funtion version are up to date and softswitch 10 is set correctly. This is the basics..where does the paper stop when it jams, any unusual noise or grinding as the paper attempts to push into the main feed area? Can you get an internal test print (gui, config page ect) to print. How many copies on the system. I assume bypass tray works as well, and if you've replaced the LCT the issue must be confined to the area where paper moves fout of the LCT and into the main feed path. Any kicks on the lead edge? We have been troubleshooting this 9901 code since the e series..E
              • afterhours
                • Mar 2017
                • 152
                Re: Bizhub 458
                Can you describe what you mean by the yellow paper seperator.
                Im a Loser Baby!!!
                • afterhours
                  • Mar 2017
                  • 152
                  Re: Bizhub 458
                  Firmware is up to date. The machine has 53k total on it. I'll check soft switch 10.
                  Im a Loser Baby!!!
                  • afterhours
                    • Mar 2017
                    • 152
                    Re: Bizhub 458
                    The paper stops when it reaches tray 2. You hear the paper buckle just before this happens.
                    If I cheat the door it comes.out of the lct just fine but then obviously jam due to the door being open.
                    Im a Loser Baby!!!
                      • 15017
                      Re: Bizhub 458
                      At the back of the tray between the two stacks of paper there is a yellow actuator. It needs to be free to move once the paper is loaded. That means there has to be a gap between the two stacks of paper.
                      • tsbservice
                        Field tech
                        • 8064
                        Re: Bizhub 458
                        Sounds like a killer second hand machine with this counter. Function version should be setup correctly according FW version but LCT problem isn't related. Initialize it from Service mode to start fresh.
                          • 15017
                          Re: Bizhub 458
                          Another thing with these trays is the spring clutch that is on the transport rollers. With the LCT door open the gray transport rollers should turn freely when you roll them upwards and lock when you roll them downwards. If not, there is a spacer that can be installed to fix it.
                          • afterhours
                            • Mar 2017
                            • 152
                            Re: Bizhub 458
                            Thank you. I'll check that.
                            Im a Loser Baby!!!
                              • 23010
                              Re: Bizhub 458
                              bizhub 658e with PC-415, J9901 and J20-02
                              Did you see this? =^..^=
