Just got 15 Bizhubs and need help
  • ComputerSupplyWarehouse
    • Apr 2021
    • 10
    Thanks for accepting me into this group!
    I am a computer and electronics recycler and just acquired 15 Bizhubs (283's 284's, 363,s 364's, 368's and 552's) with no HD's. All of the units were working at the time they were removed but HD's were pulled. I am new to copiers but after a little research I was able to get into the units and figured out how to install and format the hard drives. I am picking up drives for all the units tonight and wanted to know if there any considerations for purchasing hard drives? Are there any brands that don't play well with these units. What is the smallest recommended size? Anything else I should know?
    I have been flipping electronics for awhile but like I said, new to the copier business. I am looking to build relationships with other techs that may want to help with the sales of these units and I believe I will have more in the near future. The copiers listed here with pictures. Copiers – Computer Supply Warehouse
    Any other advice or recommendations would be appreciated. THANKS!
  • Synthohol
    Certified Konica Expert
    • 5849
    Re: Just got 15 Bizhubs and need help
    WesternDigital 320Gb drives.
      • Apr 2021
      • 10
      Is that what you recommend or what it needs? It looks like it was 160gb hdd and western digital was stock but was wondering if I used a 256gb inland would I have any issues. I know in my latitude laptops, the cheaper inland drives won't show up in a diagnostics test but will work just fine. I have a pretty good line on the Inland drives and wanted to try first.
        • 8229
        All of the meter are high to way too high. Each copier could require a ton of parts and they are all discontinued two generations ago. They are worth maybe $100.00 with HDD installed at most.
        I could not sell these for $300.00 with these high meters, even the ones at 500k clicks. The copiers with 1M+ clicks are boat anchors.
          • Apr 2021
          • 10
          That's what I need to know. This is a small part of a much larger lot of office electronics and I'm pretty green.
          • rrrohan
            • Sep 2011
            • 1977
            ive used western digital 500GB since i couldnt find any 320GB drives at my local stores.
            just make sure you stick with mechanical drives
            ive never tried a SSD but i assume since the copier was not designed for it it would either not work or it would but with TRIM support and the drive would die quickly
              • 8229
              If you are green to the business, save yourself a lot of hassle and pass on taking possession of the copiers. They are basically worthless. You might get lucky and sell one or two and then have 13 copiers taking up space in your warehouse forever. Do not be fooled that the exterior plastic covers still look nice.
              If the customer wants to dispose of the copiers, say you will do so for a fee, assuming you have the trucking capabilities and take them straight to the landfill or metal recycler. Disposal of 15 copiers has a value of $1,300.00. First find out where you can dispose of them and if there are any tipping fees at the landfill.
              Being green to the business you have no chance restoring these copiers to a reliable working condition.
                • Apr 2021
                • 10
                Appreciate the honesty. Learning the copier market is a little different animal from my main products. Still need to explore all avenues and see what I can do. Thanks!
                • emujo2
                  • Mar 2017
                  • 1579
                  I would possibly try to salvage the 8 and e series..These are still 100% supported by KM so you can find parts and consumables.. the 283, 363 came w/o HDD (option) so not needed. The 452 should be disposed of. We routinely have to add HDDs to old machines to send them back to the leasing company, and I can tell you we do not spend good money on new drives. any 250GB HDD will suffice as long as it was not in a Canon. (we use a strip salvage program to pull assemblies in decent shape from non leased returns). E
                  • REGSIS
                    • May 2016
                    • 435
                    Any SATA hdd with 256 GB and above. 320GB and 500GB tested but machines uses only 256 GB of space anyway.
                    Only 283 comes without HDD, but it can be installed as an option. You'll need a mounting plate, connecting plate, 3 shoulder screws, and 3 rubber bushings. Check 363 and 423; they have factory built in HDDs with all of the above.
                      • Apr 2021
                      • 10
                      I have got several working but I am getting an error still on a few of the units that I can't get past. I have performed the physical format but the logical format wont work. The start button stays red and I have the "Reset HDD Lock Password" error on boot. I did the "Stop - 0 - c" and turned CE Authentication OFF. I thought that would take care of the error but it didn't. Any suggestions?
                      • emujo2
                        • Mar 2017
                        • 1579
                        Someone really got lazy here..Bizhub secure was enabled and it looks like they removed the HDD without disabling this 1st. The machine is looking for the passphrase to proceed. You may try a physical format one more time. E
                        • Albonline
                          • Sep 2008
                          • 1151
                          the format did not take. doing the physical format in service mode resets the lock pw. other things that could cause this are changing boards or ssd unit willynilly between units.
                            • Apr 2021
                            • 10
                            You are correct. They just pulled drives and sent them out the door. I will try and reformat. Thanks!
                              • Apr 2021
                              • 10
                              I need to fix the error "Reset HDD Lock Password"
                              Reformatting the drives did not work. I tried to reformat drives in two of the units with the HDD Password error (363) and received the same error. I pulled one of those drives and put it in another 363 that I was able to get working on my first run through with these. The drive apparently was formatted properly (physical) and I was able to perform a logical format on that drive with no problem. Then tried to put the drive from the known working unit into the HDD Locked Password unit and had the same errors
                              So the problem is I can't perform a logical format on the units with the HDD Password error. I need to figure out how to remove the error and/or reset these so that I can perform a logical format. Is there a way to reset these units to default?
