Web browser 750i
  • kingarthur
    • 1399
    Web browser 750i
    hands up...this is probably me being an idiot. I can't get any KM to connect via the web browser. My understanding is that when you turn on the Web Browser function, it's supposed to connect to the LMS and "register" itself, then reboot, or you can generate a code on the LMS, input it into the machine, which will then reboot.
    the first doesn't happen, I've spoken to the IT who have said it does have a web connection, "as they are scanning through 365" , if I generate a code via the LMS and try to enter it I get "The settings are incorrect. Please enter the correct setting"
    Am I being stupid.....please tell me if I am.....or does something else need doing
  • Synthohol
    Certified Konica Expert
    • 5922
    Re: Web browser 750i
    is the gateway and DNS correct to reach the outside world?
    in admin, network, detail setting, ping confirmation try pinging a website.
    • emujo2
      • Mar 2017
      • 1579
      Take a look at the control panel..Is the web browser present..I have had more than a few customers struggling with this, looking in the "installed licenses" section and seeing nothing listed, call about the lack of the web browser just to find it's already there. Once you enable it in admin mode it should show up as one of the icons on the CP. E
      • kingarthur
        • 1399
        This worked for me, though the DNS & Gateway were correct, I removed & reprogrammed and it worked...many thanks
        • emujo2
          • Mar 2017
          • 1579
          My question would be why didn't the manual activation via LMS not work? That's what it's for..a machine that has no internet access. E
          • Synthohol
            • 5922
            if a machine has no internet access what good is a browser? sounds like the union/job paradox
            • emujo2
              • Mar 2017
              • 1579
              many 3rd party app connect via the web browser, the machine may not be able to reach the outside world, but the web browser can communicate with internal devices..AutoStore, OM and EQ use the web browser. E
