BizHub 363 C-C164 error
  • darichmiester
    • Apr 2021
    • 4
    I had a non functioning BizHub 363 that needed a MFP board, so I thought I found one online from a 423 that might work.
    I removed and replaced the MFP and now I have a BizHub 363 that boots up but with a C-C164 error.
    I put it on our network and i used the web app to access it and the menu indicates the pcb is from a BizHub 223! Bummer.
    I probably need firmware for a 363 to make it functional again, but seems like KM has it all that locked down unless you are a dealer or one of their preferred customers.
    I hate to beg, but can someone help me out... I would most appreciate it.
    Re: BizHub 363 C-C164 error
    what happens when you put the old board back in?
    for a small contribution to CTN i'm sure someone can help you out with firmware.
    https://www.copytechnet.com/forums/v....php?do=donate
    • tsbservice
      Field tech
      • 8081
      Phil looks like he is already a contributor.
        he wasn't when i suggested it brother.
        • tsbservice
          Field tech
          • 8081
          Understand. I will look through my files tomorrow.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4789
            Not sure why some techs here keep telling people to contribute to this website. Or dangle firmware in front of them to get them to contribute. I use to do this same thing but after several times contacting the ONE and ONLY moderator and NEVER getting a reply that was it. Game over! Now if I can help someone I do it for free and will never mention contribute.
              there are no moderators... only 1 admin... he has a family and a full time job he doesn't come in everyday... sometimes not even every week..
              How did you contact Aneurysm?
              • tsbservice
                Field tech
                • 8081
                Sounds reasonable but I have a question for you. How did this site rises money to be up and running nonstop for techs like us? There are always two sides of the coin.
                Sure it looks frustrating as hell to me when lack of moderation hits tech forums but it pays hundred times when I get or offer help from/to other members.
                Please let others decide what way they have here and stay in your course there's nothing wrong both roads .
                  +1
                  • Synthohol
                    Certified Konica Expert
                    • 5922
                    The machine type has to be changed for the new machine
                    Boot to a firmware stick and change the machine and type.
                    GQ7-D1 firmware might help but i assume you didnt swap the SSDs right?
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4789
                      Don't think it takes much work or money to keep a website running. It basically runs itself. With that said I still make a contribution every year. Could look at it that I help way more then I ask for help but I still contribute.
                      • darichmiester
                        • Apr 2021
                        • 4
                        Thank you sir... I was a contributor before I asked a question. I didn't want to be a leech.
                        I find this site quite useful when Googling problems I have with some of our network printers.
                        I really didn't think I would cause such a stir. If some one would be kind enough to help me then GREAT..
                        If not, then that's OK too.
                        • tulintron
                          • Jul 2014
                          • 668
                          Forget the fight and focus on your problem. Synth gave you the way. C164 refers to the fw incompatibility between boards. Okay, it was the board that installed it. Update according to board exchange procedure and tell us the result
                          • emujo2
                            • Mar 2017
                            • 1579
                            The 363/423 uses A1UDH0200C
                            The 223/283 uses A1UDH02108
                            They are not interchangeable..No firmware is going to help with this..E
                            • darichmiester
                              • Apr 2021
                              • 4
                              Well... you may be right... I pulled a A1UDH021 and put in a A1UDH020. I didn't even notice it till you mentioned it.
                              I just took for granted that it was for a 363/423 as per the vendor(seller). If this is true then, my mistake.
                              I guess I will use this 363 as a parts machine to T/S the other 4 we have on our network. Bummer...
                              Thanks for the heads up sir!
