Bizhub C280 fuser belt
  • Lakatom
    • Jan 2021
    • 8
    Hello there,
    Why stay previous print on fuser belt? Clean again after 5-6 blank pages prints.
    Thanks in advance.
    Best regards,
    Tom.
  • Toxic
    • 698
    Re: Bizhub C280 fuser belt
    Provide some more details...
    Machine counter, parts consumable lifes...
    On what media problem occurs?
    Did you make appropriate settings for paper weight in printer driver?
    Photo sample could be helpful.
      • 14921
      Originally posted by Lakatom
      Hello there,
      Thanks in advance.
      Best regards,
      Tom.
      Replace fuser
      • Synthohol
        Certified Konica Expert
        • 5876
        and stop using aftermarket dirt-in-a-bottle toner if thats what its using.
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1257
          Hello there,
          Thanks in advance.
          Best regards,
          Tom.
          The formulation in the generic toners is a big culprit with symptoms like that. Stop using the compatible toners if you are using them. The modern Konica fusers have nothing like the fuser cleaning mechanisms of past machines. They depend heavily on the much higher wax content and melting point specs in the new toner formulations to put out clean prints.
          The other possibility is that the fuser unit is way past it's life and you need a new fuser. What's the meter on that copier?
