Konica Minolta C364e - HATE I-OPTION 's!!
  • Kenny
    • Jun 2009
    • 524
    hi guys,
    we have a C364e in the office and i am currently trying to remove the i options on it (LK101v3 + LK110) and i an just not able to remove it. i have tried to remove is via LMS and when i put the deactivation code in it just says unable to confirm settings. when i try to remove it via the token code it thinks about it for a while and throws up error 'MDI001'. i cannot remove the LK110 in till i remove LK101v3.
    i have never really had any luck at all with i-options, is there not a way just to wipe those options off the machine?
  • zoool
    • Nov 2016
    • 52
    Re: Konica Minolta C364e - HATE I-OPTION 's!!
    try CLEAR ALL DATA in service mode.
    • strider5555
      • Jun 2008
      • 96
      Here is the deactivation procedure from KMBS
      I'm not sure if the clear all data will remove the I-options, but perhaps the reset tar file would.
      • Max
        • Oct 2011
        • 555
        Reset file and hdd format should do the trick.
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5807
          are you trying to put them on another machine? if not just leave them, it aint hurtin nuthin!
