C458 with blue LEDs below control panel lit all the time
  • adecanmin
    • Oct 2010
    • 296
    Gentlemen
    I purchased this recently. I made sure there were no jobs in the que. When I boot the machine up the LED is off until it is ready to scan then it is on. Not blinking steady blue. Machine works fine. Is there anyway I can turn this off? All my machines have the LEDs off. This is the first one with the LED on without a print job or fax.
  • allan
    RTFM!!
    • 5462
    Re: C458 with blue LEDs below control panel lit all the time
    Unplug the network cable then start it up to see if the data light stays on. Does the LED's start blinking if you send a job? Does it have a fax kit installed?
    You can unplug the LED connector for a workaround if its that much of an issue.
    Whatever
    • adecanmin
      • Oct 2010
      • 296
      No network cable attached. It has a fax. I don't want to spent too much time on it. Maybe this is easier. The tab for check consumable life under utility is missing. Is that a soft switch setting to bring it back? I really like this machine so far. The document feeder is fantastic.
      • adecanmin
        • Oct 2010
        • 296
        Found the cause of the blue LEDs always on. Corrupted data in the fax rx/tx memory boxes. Ran fax file format. No more blue light
        • adecanmin
          • Oct 2010
          • 296
          found the copytechnet thread about the consumables tab missing. Soft switch 227 HEX 00
