Getting this black deposit bottom of prints
  • positiveg
    • Jun 2018
    • 299
    Good day getting this from my C454
    Not sure where it's coming from or what's causing it.
    Please assist got these booklets to finish up thanks
    Sent from my SM-G955F using Tapatalk
    • 14614
    Re: Getting this black deposit bottom of prints
    Take the drum apart and clean the grid. If that doesn't do it you will likely need to replace the dev unit. Check life counts and replace any drums that are over yield.
      it looks like drum issue to me.
      i take it the paper feed is LEF... have you tried running it SEF that should remove remove the defect from the print.
      what are the page counts on drum/dev... also take a look at the ITB for a like smear. Do a stop test to see if it's on he belt
      • tulintron
        • Jul 2014
        • 668
        Developer and drum are in contact for some reason. Check DU and UI
        https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
        • positiveg
          • Jun 2018
          • 299
          Ok cool will check the SEF/LEF and go from there.
          Then will also check the IBT. And get back to you.
          Will get yoy the numbers on the drums as well thanks
          • tsbservice
            Field tech
            • 8001
            This isn't right image to post. We need separation go in SM and print CMYK halftones. Then if all 4 colors are affected it's ITB. If only single color is affected you will know where to start.
              well brother I agree but I work with what I'm given.
              • mojorolla
                The Wolf
                • 2604
                Wait a minute, this is a booklet; it can only SEF.
                  from the look of the smears I don't agree.
                  • tsbservice
                    Field tech
                    • 8001
                    Completely agree Phil.
                    Completely agree mojorolla.
                    • mojorolla
                      The Wolf
                      • 2604
                      Go back to trolling Phil, that's the dumbest shit you ever posted, and that's saying a lot.
                      EDIT: Hey Phil, thanks for the downvote. I gave you one too for shit advice.
                      • positiveg
                        • Jun 2018
                        • 299
                        Phil made an error.
                        But anyway seems like the IBT belt did have some smears on it. So was right there.
                        These are the numbers on the consumables.
                        • Synthohol
                          Certified Konica Expert
                          • Mar 2016
                          • 5812
                          if its not the drum/dev a clogged waste port from the belt is my next thing to inspect.
                          its a little bit of a pain to remove and clean but can be done in 15 min. (on the 4 series at least)
                          the port from the belt to the WTB, not the belt cleaning port on the belt itself.
                            how big is the finished product?
                            is it folded?
                            what is the size paper you are using ?
                            • positiveg
                              • Jun 2018
                              • 299
                              is it folded?
                              11*17 folded. To me it also felt like there was a li'l back up going to the waste toner cartridge. But I ran a print after ans it's good. This is 11*17
