slanted image on scanning
  • jwai
    • May 2018
    • 508
    Hello,
    One customer found the image on PC have been slanted about 2 degrees.
    I placed one sample on original glass and got scan, the issue occurred.
    However the cartridge of 2nd and 3rd mirrors seems not have any screw for adjustment,
    so how to fix this case?
  • tsbservice
    Field tech
    • 7999
    Re: slanted image on scanning
    Originally posted by jwai
    Hello,
    It might be useful if we know the model.
    • rrrohan
      • Sep 2011
      • 1977
      I just loosen the screw that clamps scanner to movement wire and shift it 1mm, tighten it, push scanner back to far left, reinstall glass, close and open ADF twice to make sure everything is in its correct home position then do a test copy off glass. Repeat until straight
      Sent from my Pixel 4 XL using Tapatalk
      • jwai
        • May 2018
        • 508
        bizhub C450i.
        • tsbservice
          Field tech
          • 7999
          bizhub C450i.
          There is procedure in SM for skew adjustment when images are tilted when scanning or copying. I would try it.
          • Synthohol
            Certified Konica Expert
            • 5808
            Maybe some putz leaned on the front left corner of the scanner and bent the frame.
            Put orig on glass and lift up the front left corner with medium force and scan again. If it's straight someone bent the frame.
            If still skew check ALL trays in case the paper is just loaded sloppy
            • Gift
              • Mar 2011
              • 2459
              +1 for the scanner bent theory - and don't check it with copy function, just scan a sample on a thumbdrive and check the result with your laptop.
              • jwai
                • May 2018
                • 508
                yes, i printed the bird test page it's fine.
                next i took this page as original and got a scan to PC through original glass, the image had been slanted approx 2-3 degrees.
                • Synthohol
                  • 5808
                  did you lift up the front left corner with medium force and scan again or jumped right to the screwdriver?
                    bet he didn't take the time to try lifting. bent frames are common.
                    • jwai
                      • May 2018
                      • 508
                      I lift the scanner several times and got the test, it seems reduced approx 1 degree.
                      • mascan42
                        • Oct 2008
                        • 484
                        Usually with the bent frame, the lead edge will be skewed, but the top & bottom edges will be straight. Is that the case here?
                        • allan
                          RTFM!!
                          • 5462
                          Running the setup chart and doing the auto adjustments can help.
                          Whatever
                          • jwai
                            • May 2018
                            • 508
                            Got a copy/scan a rectangle figure on A4 paper through original glass, the image will rotate a bit.
                              • 23002
                              We used to call that the Ricoh bear hug, since it was so prevalent on Ricohs of the mid 90's.
