C3100p Wireless printing
  • Kenny
    • Jun 2009
    • 533
    Hi Guys,
    can a C3100p be set up for wireless printing? does anyone have any suggestions on what adapter to use for it, if it can?
    any suggestions would be appreciated
  • Toxic
    • 698
    Re: C3100p Wireless printing
    You can use any router or access point with client mode function.
    Set router to connect to your main wifi router and plug lan cable from router to C3100p.
    • rrrohan
      • Sep 2011
      • 1977
      Tp Link make them. The wall plug version works well. About 100 dollar re doos
      Sent from my Pixel 4 XL using Tapatalk
      • Gift
        • Mar 2011
        • 2459
        • Synthohol
          Certified Konica Expert
          • 5892
          Amazon.com: TP-Link AV600 Powerline Ethernet Adapter(TL-PA4010 KIT)- Plug&Play, Power Saving, Nano Powerline Adapter, Expand Home Network with Stable Connections: Computers & Accessories
          plug 1 into router/switch the other in the printer.
          uses ethernet over power.
          bought a dozen sets for work already. they are solid!
          • emujo2
            • Mar 2017
            • 1579
            You can add the NCP03 (along with MK P07 mount kit) to give the machine wireless features, but it probably is cheaper just to cable it to a wireless LAN access point. E
            • tsbservice
              Field tech
              • 8053
              Much cheaper.
              • copier tech
                • 8200
                Originally posted by Kenny
                Hi Guys,
                As many have said use a range extender. This one works a treat, simple to set up & costs peanuts.
                RE220 | AC750 Wi-Fi Range Extender | TP-Link United Kingdom
                • Kenny
                  • Jun 2009
                  • 533
                  thanks for the suggestions guys, its a big help
